Question about Toshiba Satellite P105-S6104 Notebook
Mouse pad Satellite P-105-S6217. How do I disable the function where the mouse pad lights up blue and allows use of the shortcut items. I don't use them and it is very distracting when I accidentally activate it. Thank you.
  • Sandi Martinez
    Sandi Martinez Oct 12, 2008
    The only way out that I have been able to use, is alt ctrl del, and logoff. This is VERY annoying, and I have found no answer anywhere!
The program that controls the functions on the pad is called Synaptics. If the small red Icon does not show on your task bar, you can find it in program files. I had the same issue and turned it off. I forgot how I had done it so it took me a while to remember where to go to turn it back on. Right click the icon and go to properties. Then go to device settings and you can disable it or change settings however you like. Hope this helps you.
Posted on Oct 17, 2008
My cursor will not move using the mouse pad on my Dell latitude 3330
If you have an external mouse, the mouse pad will be turned off.
There is a setting in the BIOS that allow both to function at the same time.
In windows control panel, there is an item to enable (the been disabled) mouse pad.
Aug 22, 2014 | Computers & Internet
I want to disable the touchpad and use the external mouse exclusively
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Toshiba Satellite P305DS8836 Notebook
Orange light on mouse pad came on preventing use
Press the button above the touchpad where the amber light is, when it turns blue the touchpad will be enabled.
May 01, 2011 | HP Pavilion dv9000z Notebook
I can't find any information re Windows CE. All I want to know is how to use the help page and how to disable the mouse pad.
Hi ms_k7582,
To "Disable" the Mouse Pad, or ("Pointer Device")!
Select the Control Panel, in the 'shortcut menu.
paul7of9_142.jpg Next, select the Device Settings, in the [Devices] block.
Click on, to "highlight the item you want to [Disable]."
The "Pointer Device, this will also 'Disable' the "Touch Pad"
Click the "Disable Button," just below.
"Always, ("click") on the, "Apply, and OK buttons before exiting."
*Note: Restarting the computer will configure system changes.
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
Mar 07, 2011 | Sylvania G-Netbook
De activating num lock key only enables cursor movement in four directions. how do you get the number pad to enter numbers?
This is a Windows feature called "mouse keys", it can be disabled by using the shortcut left-alt+left-shift+num lock.
In Windows 7 mouse keys settings can be found by following Control Panel\All Control Panel Items\Ease of Access Center\Set up Mouse Keys
Nov 07, 2010 | Logitech Classic 200 DH968019 Keyboard
How to unlock a laptops mouse
i'm going to assume you are tryign to unlock the mouse pad to use it again.
on the keyboard there is an Fn key. This is called Function. then there are either gray or blue alternate pictures and words on some of your keys. along the top on the F keys you can fidn one that looks liek a picture of the mouse pad. this is usally F3 on those.
hold down the Fn key and hit the F key that has the correct picture. this will reenable the mouse pad
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
I would like to disable the sensor pad and i followed mr fix it guys instructions FN/F9 didn't work and I could not find the disable function in mouse properties
Sometimes the "scratchpad" mouse has a separate icon from the mouse where it can be adjusted or disabled. Check control panel for this.
Oct 21, 2009 | Toshiba Satellite A355-S6930 16.0-Inch...
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software:
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
My touch pad on toshiba will not work.
Hold down the function key and press F9. That enables/disables the touch pad. The function key is the one with the letters 'Fn' on it. If that doesn't work, let me know and I well explain the long answer.
Good luck, and let me know how you made out. and please rate my answer.
Jan 17, 2009 | HP Compaq Presario v3000z Notebook
Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Oct 27, 2008 | Toshiba Satellite A15-S157 Notebook
Toshiba Satellite P105-S6104 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
