Question about Ingersoll Air Tools & Compressors
Little air in compressor
Debit in compressor it's very low
  • 104 Answers
Can't help you need more info
Posted on Oct 16, 2008
How to set the pressure regulator valve so yhat it stays on pressure.
pressure is related directly to volume
If you have it set as an example on 60psi and the tool you are using requires 15 cubic feet a minute to drive it but the compressor is only a 12 cubic feet a minute compressor the the regulator has a debit of 3 cubic feet of air coming in so it will drop pressure
you cannot get constant out of a regulator if less is coming in to maintain the pressure
Dec 09, 2017 | Air Tools & Compressors
R134a system, low and high side pressures are low (33#-160#) pressure does not rise significantly with hi rpm, warm air, cold line sweats very little, very little drip from evaporator.
Those reading indicate the system is either low on charge or the the compressor is failing, I would do a refrigerant recovery and vacuum it down to 30 inches and recharge it.
Oct 10, 2016 | Cars & Trucks
Very little air pressure, unit was working great then all of a sudden very low pressure coming out. Unit runs fine, I disconnected hose but same issue.
RonV:
Run the compressor up and use a soapy solution to find the leak(s). Especially check both ends of the tube running from the compressor head to the tank.
Aug 16, 2013 | Master Heaters Flow MF1050 Tsunami High...
No AC, then recharged, now compressor makes on/off clicking noise while running with AC on
This still sounds like low pressure. If you re-charged a system that was low, and didn't pull a vacuum and evacuate the system first, then you still have air in the system, which is causing the compressor to cycle on and off.
Jun 07, 2012 | 2006 Ford Taurus
Wont build up air presher on ec12
Low pressure ususally caused by faulty reed valves /gaskets in the head. Easy to check. When compressor reaches highest pressure, check for air blowing out of the intake or no or very little suction. If the compressor has reached highest pressure and you still feel very good suction, suspect air leaking out of system. Check all fittngs with soapy water or shut off the compressor and listen carefully for air leaks. Repair as needed. If faulty reed valves, you can make them using feeler gauge material or purchase from www.toolpartsdirect.com
Oct 21, 2011 | Hitachi EC12 Portable Electric 2hp Air...
My 1990 testarossa air conditioning is not blowing out cold
Hi! ss519
Do you have guages or electrical meter. Will the compressor run, if the unit is low on freon, the low pressure switch will not let the power feed the compressor clutch. Just need a little more info.
InMrFixIt
Jun 19, 2011 | Air Conditioning and Heat for Ferrari...
Low pressure hose cooling system
on my 2000 expedition it is located on top of the compressor. The compressor is barrel shapped and silver and has a belt attached to it. There are 2 ports on the air compressor, one low and one high. When charging your air conditioner the gauge will only attach to the low pressure.
Jun 07, 2010 | 1999 Ford Expedition
Air cond. Compressor doesn't turn on Is there a separate switch?
Well yes, there is a separate switch. If the A/C system is low on freon, the low pressure switch will keep the compressor from engaging to save it from damage due to no lubrication. The freon helps with lubricating the compressor. Get you a can of 134a from the parts store and add a little to see if the compressor will come on. It should come on before one can is used. Now for the freon to be gone means you have a leak. So if the can gets you cooling, try to find the leak so you can stay cool.
May 15, 2010 | 1995 Ford Taurus
Air Conditioniong not working
U may be low in Freon gas.
When Freon is low there's low pressure switch that will prevent A/C compressor clutch from engaging to protect it from failure.
So, first check Freon pressure & any leaks form lines & hoses fittings.
Even if the fan is working, that doesn’t indicate proper compressor OP'S.
Look at the compressor front side you'll see the clutch stationary while the AFT pulley moving.
Then put air-condition compressor switch to ON (Engage),
You should see the clutch engage & start rotate,
If NOT, this is very clear indication u r low in Freon.
Regards;
MAR
Jun 03, 2009 | 2003 Dodge Caravan
Starting and stopping of air compressor ( no leaks)
This can depend on many variables . (1) How big the air tank of the compressor is, (2) how many PSI the compressor is set to hold, and (3) how many PSI your air gun uses per shot. If you gun is rated at a very high PSI and your compressor has a small tank and low PSI, you may want to consider investing in a larger tank.
Mar 22, 2009 | Coleman Air Tools & Compressors
Air Tools & Compressors Logo
49 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
