I want to format my maxtor 160g from ntsf to fat32 to view between xp and mac
  • 4 Answers
Depending on whether you want to keep the data currently on the drive, you can use a program such as Partition Magic or similar to alter Partition characteristics (I would strongly reccomend you back up all data before doing anything though) the other option is to format the drive before installing an OS such as XP. I believe the installer for XP home allows you to format to FAT32 if you wish (not sure about that) if not you should be able to do it with Partitioning oftware from within windows or with a boot disk which contains a version of fdisk with large drive support.
Posted on Oct 08, 2008
How to reformat a external hard drive to ntsf
Insert the USB hard drive into the PC's USB port.
Go to Control Panel - Administratve Tools - Compurt Management - click on Disk Management - scroll down and click on the external haqrd drive, delete the HPFS partition (this is the MAC file system), create a new partition NTFS - format this partition.
If you want to use this external dirve to exchange data between the PC and the MAC the format this hard drive in FAT32.
The MAC can read and write files in FAT32.
Apr 16, 2012 | MicroNet Technology miniMate MM80 80 GB...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Is alpine going to upgrade the usb formay from fat32 to ntsf for playing memory sticks in unit or how do you format music to fat32 on a windows xp ntsf format without wiping out hard drive
The Alpine CDE-103BT requires only USB media that is FAT12/16/32. You can format your USB medium on your PC to FAT32 then copy your media (music) to the the USB drive.
Insert your USB Drive to the PC On your PC navigate to Start ->MY Computer Then locate your the drive that is your USB Drive. At this time you will want to save any of your data before continuing. All Data on the USB drive will be lost. Next ensure that you have selected the correct drive. Right Click on the drive on go to format... Under File System select FAT32. I would suggest leaving Quick Format unchecked. So you ensure that will information is removed. Then Click start. Next copy your media (music) back to the USB Drive. Insert in to the CDE-103BT Stereo.
Notes: MP3/WMA/AAC files are prepared, then stored to a USB memory. This unit can recognize at least 100 folders (including root folder) and 100 files per folder stored in USB memory. Do not make a file's playback time more than 1 hour.
Nov 07, 2010 | Alpine CDE103BT CD Reciever iPod and USB...
I have been using Maxtor basics desktop 500mb with my desktop PC (XP) for a year. Now I have an Apple Mac Mini and so I want to use the Maxtor with the Mac and access the files on it from the Mac (OX Snow...
Looks like you may not be in luck.
I found this on a forum.....
When you have the hard drive connect to the Mac, right click on it's icon and select Get Info. Look in the window that pops up and see what is listed next to Formatting. It it says NTFS, then the Mac can't write to it. Being it is a large drive, that you have been using on a Windows PC, I'm 99% sure it is NTFS. In order for the Mac to write to it, you will have to erase and reformat the drive. If you will only now be using it on the Mac, then you can format it Mac OS Extended (Journaled). Just remember, that by doing so Windows now will not be able to read or write to the disk. If you do need it to work with both platforms, you will need to see if Maxtor has a utility to do the formatting. Because of it's size, I know that Windows will not format it FAT32 (which is the format you need it to be in for both OSes to read and write to it) in one drive as Microsoft has limited FAT32 formatting to only 32Gb, but can read FAT32 drives of almost any size. The Mac can format MS-DOS (FAT), but I have not had the greatest luck in formatting large drives with it. The Mac will see and read/write just fine, but many times, Windows will not see the drive. I know that most drive makers do have a utility that runs under Windows (some even have Mac ones) and will format it for you in FAT32. There is one downside though, you will not be able to have a file greater then 4Gb in size due to a limitation is the structure of the FAT32 data table
Aug 05, 2010 | Computers & Internet
So, my external hard drive was once used on a computer using Windows. Everything that has been installed onto this is locked. My computer is a Macintosh. I cannot add new files or delete the old ones from...
If your external HDD was used on a windows machine, it was probably formatted in the NTFS file format. Mac uses Fat32. The entire HDD has to be formatted to Fat32 for the Mac system to use.
Jan 28, 2010 | Maxtor OneTouch II Hard Drive
My 160g freecom hard drive has stopped showing my files says its empty but i have 20g of space used how can i get them to show up again?
make sure your reading the files on the same type of system.. if it is formated in NTSF you can only read in in newer windows systems, if it is in FAT32 it needs to be read on a fat32 system
Sep 12, 2009 | Freecom (24358) 160 GB Network Hard Drive
ACOMDATA 160g E5 compatability
By default, the disk is formatted as FAT32, a format that bothe the MAC and PC understand.
Dec 13, 2008 | Acomdata HybridDrive E5 Hard Drive
I had my maxtor one touch 4 750 gb external hard drive installed on a dell laptop with windows xp i plugged it into a mac and installed it but couldnt get it to work so i plugged it back into my laptop and...
Hi there, I think it may be to do with the format of the harddrive - see if you used the Maxtor in a Windows XP environment it would have been formatted to suit that OS.
Is the Harddrive formatted to NTFS?
Jul 22, 2008 | Computers & Internet
Re-partition external HD for windows and mac
Back up all the data on the disk to your Mac. Plug the disk into your Windows computer and format it with a FAT32 filesystem. Both Mac and Windows can use FAT32. Do not format as NTFS.
Jan 18, 2008 | Computers & Internet
FreeAgent Drive is Read Only on Mac OS X
OK, after having read through these responses and having tried some different things, I wanted to post what worked for me, because there seems to be some confusion here. First of all, I took the route of trying the ntfs-3g driver. I downloaded it and looked at the directions for a Mac. I have only had my Mac for a little over a year and working with Fink or whatever was not user friendly, so I looked elsewhere. It turns out that Mac does INDEED do Fat32. As one of the other sites that I read says, it is not really very clearly done, but if you use the Mac disk utility application (it comes with Mac OS - I am using 10.5), then you can reformat the disk. It says "MS-DOS (FAT)" for creating the partition, but if it is a large partition, then it will automatically use FAT-32. So I have just formatted my 1.5 TB Free Agent drive with that and copied a .DOC and .PDF file onto the drive. It works fine on the Mac. Then I take it over to my Windows Vista machine, plug it in, and Windows Vista recognizes it, opens the Doc file in Word, the PDF in Adobe Acrobat, and it sees all of the disk space on the drive (after formatting, it says it is actually a little over 1.3 GB - Western Digital stretches it a bit by calling it 1.5 GB). Anyway, the bottom line is that it seems to work like a charm. One caveat is that apparently formatting such a disk with Windows Vista is limited to 32 GB partitions (see MS docs here - http://technet.microsoft.com/en-us/library/cc766145.aspx). However, that seems to be arbitrary and set by Microsoft and is not a technical limitation of the FAT32 technology. So that is how it worked for me.
Jan 04, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
