Question about Compaq Presario 1200,1600 (297657-001) Internal 14x CD-ROM Drive
Nero burning on cd writer
I have hp compaq presario 1000. Dvd rom and cd re writable was the installed drive. When I use nero 7 to burn no features will come out in the nero. when I save files thru cd write my laptop cant detect a cd rom driv. But when i play vcd and dvd movie or audio the driver plays. Whats the problem with my DVD- CD re writtable drive?
    President:
  • 216 Answers
Use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
I have 32 bit windows 7- I try to burn the back up dvd's and everytime it either says to please insert media ( its inserted) or it says media needs formatted? I have tried like 50 times and no go every...
are you sure that it is a dvd writer >??? and not a cd writer ..dvd combo?? in this case you can not burn but a cd..and play the dvd ...Im saying this cause most of them are equipped like that it plays dvd-es but burn only cd-es..another thing try to install a bunner like nero ..or iso hunt ...if it doesnt want to ..maybe is all in right with the os...in both cases try to burn an image on the hdd ...like in a game that came iso...just choose burn image ..or change the device into the image burner ...and will burn a image with the recovery dvd you want to ...this one export it to another computer on a memory stick ..and burn it to a disk..
Mar 29, 2010 | HP Compaq Presario C700T
DVD/CD reader writer
it may be fault of the dvd writer and also uninstall the nero and then reinstall it .................
May 24, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Need help with Compaq Presario v2000 drivers
Your DVD drive is missing the Burning Program not the driver. I found an update for your windvd software for windows 7 but you probably have to have the full program installed to run the update. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432985&prodNameId=500746&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ob-26952-1
Jan 10, 2010 | HP Compaq Presario V2000 Notebook
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Compaq 6710b Notebook
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Dvd writer does not burn on raw file system cds
What OS are you using? I doubt it is the burner. I have the same model burner and it burns everything I try to burn just fine. It works on both my XP SP2 installation and the OS X86 Leopard 10.5.5 installation. I have burned video, data and bootable OS DVDs and CDs in both operating systems.
It may just be Nero. You could try Alcohol 120% or Ultra ISO.
Dec 27, 2008 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My cd/dvd rom no longer reads or burns
The laser that reads (or "burns") has failed.
Spend $30 to buy a new CD/DVD reader/writer.
Nov 16, 2008 | Compaq Refurbished 7 EVO N410C DVD/CD-RW...
Cd burning drive
ARE YOU SURE THATS A CD WRITER NOT JUST A CD ROM. IF ITS A CD WRITER AND YOU ARE USING THE OS AS WINDOWS XP....JUST TRY SENDING THE FILE DIRECTLY TO THE BLANK CD IN THE DRIVE...IF IT BURNS THE CD WRITER IS OK AND THE APPLICATION (NERO OR WATEVER) YOU ARE USING TO BURN THE CD REQUIRES TO BE REINSTALLED
Apr 21, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 1200,1600 (297657-001) Internal 14x CD-ROM Drive Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
