Question about HP LaserJet M4345 MultiFunction Printer
Laserjet 4345 mfp paper jam
I receive message on the monitor saying: "13.20.00 Paper Jam on tary 2" and signals how to remove the problem. I did it, I 've seen above the tray, I opened the printer, no paper is there. can any one help me?
  • saadialfa Oct 11, 2008
    Thank you mickect. I've tried all this solutions, but the message still appears and the printer can't print.
  • tgoral Dec 03, 2008
    Have 13.20.00 codes, removed tray 2 and right door to check for paper,all clear and clean,blew it out with canned air. Removed and reseated fuser. powered on and same problem.
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Posted on Oct 08, 2008
  • Chafadza Mafukidze Nov 01, 2012
    i also have a similar problem.The printer says paper jam tray 2 whilst there is no paper inside.sometimes it prints one page then it says 13.20. paper jam.any solution to this.I will be using tray 3 but it says paper jam in tray 2
2 Suggested Answers
  • 224 Answers
SOURCE: HP Laserjet 4345 mfp paper jam.
recycle the power to reset
Posted on Mar 31, 2010
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
Bad problem , check if there is some piece of paper ... otherwise yuo need a thecnic , may be is a paper sensor damaged .
How do I repair Paper jam message but no jam
First step is to unplug your printer, leave it unplugged for 30 seconds and then plug it back in.
Aug 03, 2014 | HP Hewlett Packard Laserjet Pro 200 M275nw...
False paper jam on hp laserjet 4345
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 06, 2013 | Office Equipment & Supplies
PRINTER COULD NOT AUTOMATICALLY EJECT PAPER HP 4345, with error code 13.20
Check inside the MFP (manual feed tray) for a scrap or a whole sheet of paper.
There is one of three sensors that is sending a paper jam notice to the printer.
Nov 05, 2011 | HP LaserJet M4345 MultiFunction Printer
Error code 13.20.00 for hp laserjet m 4345 mfp
Hi!
According to HP service manuals, the error you described is in the category:
JAM INSIDE TOP COVER AREA
and more specific:
The pre-feed sensor, the top-of-page sensor, or the fuser-delivery
Those are the points where some paper pieces or even dust can be stuck.
Hope it helped,
Bogdan
Aug 30, 2011 | HP LaserJet M4345 MultiFunction Printer
Hp 4345 won't lift paper says paper jam. I open the tray close it and it works for one paper. Then it happens again.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 31, 2010 | HP LaserJet 2840 Printer
HP LaserJet M3027 indicates paper jam but there isn't a jam.
if you are getting a paper jam message but you can not find paper any where in the printer the first thing that you want to do is clean the pickup roller in the paper tray. the roller is located on the top of the cavity that the paper tray is installed in.
Mar 11, 2009 | HP LaserJet M3027 MFP All-In-One Printer
I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
Jan 05, 2009 | HP LaserJet M3027 MFP Printer
HP LaserJet M4345 MultiFunction Printer Logo
3,728 people viewed this question
Ben Johnson
