Question about Neff W4380X1 Front Load Washer
Neff W4380X is showing error code 01
The washing machine will fill up but not rinse. it gets part way through the cycle and shows error code 01 when trying to fill to rinse.
We have recently moved the machine after a refurb in our utility room and the problem has started occurring. Any help/suggestions?
Thanks
  • Anonymous Mar 17, 2014
    Unable to open door pressed start pause before cycle had finished
    Sergeant:
  • 228 Answers
Error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Posted on Oct 28, 2009
Machine stop at rinse.
stopping at a rinse cycle usually means a bad fill valve (no cold water)
the machine is waiting for cold water and will not continue until satisfied
Oct 20, 2014 | Neff Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Im having trouble with the settings on my fisher and paykel intutivie washing machine.It will wash but not rinse or spin. What can I do?
Hi just read your posting.Now, does the machine drain the water?Does the machine stop and beep and show an ERROR CODE?Does the machine fill for the rinse part of the cycle?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 03, 2010 | Washing Machines
Washing machine fills at the start but when it reaches or it put straight onto a rinse cycle, the machine doesnt fill with water, it agitates and spins and lid locks. I have already read a couple of posts...
Hi Chic, just read your posting.Now what wash temp have you selected?Is it warm, cold or hot?Have you tried a cold wash?Does the machine beep and show an ERROR CODE which are a series of lights on when it is beeping?Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code 01 on bosch dishwasher. what does this mean?
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
May 27, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
V5340 error code 14
first check if your tapis open if ok, check your water valve if it is clogged or busted, it is th electrical devise that controls water flow to your machine, if it is busted replaced the water valve, check the nearest part center in your locality, , otherwise a tech should check the unit, error code from 10 to 15 refers to water supply of your machine sir.
Mar 19, 2010 | Neff W5340X0 Washer
Washing cycle won't spin - fills and rinses but stops
the brushes in the motor sound like they need replaced
Mar 01, 2008 | Neff V4380X0 Front Load Washer / Dryer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Neff W4380X1 Front Load Washer Logo
688 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
