Question about Sony VAIO PCV-V210P PC Desktop
Computer will not start past safe mode screen
When computer is turned on it shows a safe mode screen with 3 safe mode options for turning the comp on or just leaving it for windows to start normally.
Have tried all 4 options, windows screen flashes and then safe mode screen returns with same options once more.
Last use prior was normal and shut down properly.
  • Anonymous Nov 25, 2008
    It says move the mouse or press any key to pass this mode, i press it but nothing happens
  • dbond2179 May 11, 2010
    when you say the windows screen flashes and the safe mode screen appears again. does the computer reboot?
    also have you installed any new software/hardware recently?
  • 749 Answers
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Posted on Oct 08, 2008
My dell laptop inspiron 1100 won't start up. When I turn it on it go's to a screen that says it's now installed firmly in to the port bay and I can't get past that screen. I've tr
Turn off the computer. Hold the Fn key and power key to boot the computer in diagnostic mode. Follow the onscreen instructions to see if you have any hardware issues. This sounds like bad sectors on the OS boot partition.
Jun 28, 2017 | Dell Inspiron 1100 Notebook
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
My comp says i need to turn off safe mode its preventing certain things from loading
Hi, open your computer in safe mode and uninstall some newly install software. Otherwise--
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 17, 2011 | Computers & Internet
Windows\system32\config\system file missing or corrupt
you will get this error once an important file or files on your pc had been deleted or infected by virus. you need to scan your pc and perform a registry scan.
Apr 16, 2011 | Computers & Internet
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
Feb 02, 2011 | Computers & Internet
Another computer problem, my ******* downloaded a virus file called red cross, now i turn on my computer and all it says is red cross, how do i get rid of it? how to i get system restore when i cannot get...
You will have to login to the Safe mode option and run a spyware scan.
Kindly download and install Malware Bytes application which is a freeware and easily available in web. Once installed follow the steps below
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode".
Step 5: Select that and HIT ENTER.
One you are in the Safe Mode Run the Malware bytes scan (Quick Scan)
Dec 19, 2010 | Acer Aspire One PC Notebook
I have a compaq v 2000 and when i turn on the comp safe start menu comes on then when i type enter for start windows normally a blue screen shows up and the computer cuts out or turns off automatically...
Unplug all additional devices, printers, external drives, network cards, etc. If it won't boot into safe mode, you will need a windows disk. Load the windows disk, and if it's Vista or 7, get the advanced repair options, and do a system restore. If it's XP, just do the computer repair. Windows vista also has a startup repair you can run from the Windows disk. We need to know the operating system to help you
Jun 13, 2010 | Computers & Internet
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
Do not choose the option to press R to use the Recovery Console.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Keeps turning off
Sounds like a hardware failure. Possilbly the motherboard, more than likely, the power supply.
But then - maybe neither.
Shut it off completely, once you restart, start hitting the F8 key ( once a second ) until you see the " Safe Mode" choices screen. Drop down and select the " Last known Good Configuration" option and hit enter.
If this doesnt work, try the same proceedures ( restart - F8 ) but this time select safe mode - at the top of the list.
If you sucessfully boot in safe mode, you have a system file problem that could be virus related, file table corruptions or registry problems or all combined.
We're here if you need us.
Oct 10, 2008 | MSI PT880 Neo FSR Motherboard
Sony VAIO PCV-V210P PC Desktop Logo
252 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
