Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
Fan is it wise to lubricate a ball bearing CPU fan? cause i jus i did that,am i screwed, cause the noise has become suddenly louder...
  • 4 Answers
As fans with ball bearings in them operate, they gather dust. this dries out the lubricant in the bearings track. normally cleaning the fan would suffice to restore effectiveness just run a vacuum over the fan on a regular basis to stop the dust building up.
if you have added lubricant to the bearings you may find that more dust is now sticking to the dust that was already there reducing the fans effectiveness even more and causing more noise.
another possible reason for the increased noise is that when lubricating the fan, depending on how you did it, you may possibly have bent the fan's axle slightly again increasing vibration and noise.
personally I think it unwise to add lubricant to a ball bearing track such as that on a cpu fan as lubricants vary in viscosity and suitability for use and I wouldn't know which one to buy. If the axle has become bent, I believe it is possible to have it straightened but with the price of fans being so low I feel your best course of action would be to replace the fan and then make sure that your new fan doesn't get clogged.
Posted on Oct 08, 2008
Ceiling fan makes noise, rubbing noise?
Ceiling Fans making a Grinding Sound. If it's a grinding your hearing, most likely the ball bearings in the motor are bad. Some ceiling fans have flywheels that attach the blades to the motor. If the flywheel is sagging or has broken, the blade irons might be scraping on the top of the switch cup housing.
Feb 09, 2018 | Dryers
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
2002 camery roaring from front seems louder when slowing down. It is not brakes
check wheel bearing...transmission output shaft bearing. noise is louder because when bearing slow down, they get louder from worn down ball bearing inside the cage, space is developing between the ball bearing..caused by lack of lubricate, or just worn out bearings
Aug 01, 2012 | 2002 Toyota Camry
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
Dimension 3000 gets noisy when the weather gets warm
I'll have to guess exactly what gets noisy. I'm afraid the crystal ball is in for a service :-)
If you put your ear close (NOT THAT CLOSE) to the rear where the cooling fan sits is the noise much louder? If so, it could be a fan about to dry out and fail. Many of them are cheaply built and don't use a ball type bearing. I don't normally recommend this trick but what I do is inserta plastic probe or the end of a plastic spoon just inside the grill just enough to stop the fan from spinning when you switch it on. Switch on the computer with the fan stopped and if the noise isn't there you have a fan requiring replacement. Don't leave it on for anymore than a few seconds. It's a cheap and nasty way of doing things but us techs tend to prefer this approach.
If the noise sounds internal it could be a hard drive with bad bushes if it is back up all your data and replace the drive before you lose all your info. Or possibly the fan which cools the CPU is heading to meltdown. If it is the cause of the noise, replace it immediately.
Another trick I'll let out of the techs bag is to get hold of a short (18inches) piece of rubber tubing. Hold one end near your ear and the other near where you think the noise is coming from. once you find the right spot you'll know it's the right one, believe me. Just don't jam it into fan blades even the small cpu fans can cut your finger open. Also check for larger cooling fans dotted around the case.
I'm a betting man and I'll lay odds it's the power supply cooling fan at the rear of the computer near the power inlet.
Apr 10, 2010 | Dell Dimension 3000® Pentium® 4...
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
I noticed a louder engine sound at approx 45 mph, like a humming or aceleration sound, I had the driver's side wheel bearing replaced to the tune of approx $300 but the sound still remains (the repair guy...
Chevrolet has a common problem with integral hub and wheel bearings wearing due to exessive use or lack of lubrication, the balls or rollers and races become pitted ,scored or just plain damaged which will infact cause a loud humming or growling noise. I have had some humm at about the same speed but usually they will start to make noise at any speed. I would have to hear the noise to be sure cause there are many things to cause a humming noise like odd tire wear, bad idler pully bearings, e.t.c. the tires should be lifted checked for excessive play in the bearing. Take tire off depress brake piston in just enough secure brake rotor use stethoscope spin hub while listening. maybe he replaced wrong side seen that alot, seen tire noise mistaken for bad bearing to if struts or shocks are worn can cause tires to be choppy. I would recommend taken back 300 dollars is alot of money to not fix your problem.
Jul 15, 2009 | 2005 Chevrolet Equinox
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
CPU Fan.
Make Sure your thermal compound is properly placed, check the temp of your CPU. CPU might be overheating due to destroyed layer of compound and therefore Fans run faster...
Sep 27, 2006 | Gateway 500GR PC Desktop
Computers & Internet Logo
219 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
