Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I can't turn off the grinder- sometimes it just starts up in the middle of the brew cycle- sometimes it wont even start- i have only had this machine GRIND& BREW coffee maker about 6 mo- is this fixable? kl
  • 8,596 Answers
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
It grinds the beans, but just a trace amount of coffee is brewed and drips out.
My F9 started with the "Fill Beans" routine even though there were plenty. The grinder started making a high-pitched noise, which Capresso's customer service told me was indicative of something being stuck in the grinder (like the stones mentioned in the manual).
Their suggestions ranged from vacuuming out the grinder to blowing compressed air into it, to "burping" the machine -- which they describe as hitting it mildly while grinding. Kind of a Heimlich maneuver on the thing.
Still no success, but I did turn the unit upside down a few times and shook out a *lot* of coffee grounds. This led me to believe that the grinder was still working, but something was blocking it down low. So I ran the cleaning cycle twice, and voila, coffee again.
An interesting aside was that the first dump from the first cleaning delivered the usual grounds but also some more pasty-like remains, and pretty dirty water. The dump water from the second cycle was very clear. This is a testimonial to the efficacy of the cleaning process. If you don't do this when the machine requests it, you are running the risk of gumming it up. I know (now); I had been ignoring the request to clean it for about a week and a half...
Dec 26, 2009 | Jura Capresso Impressa F9 Espresso Machine
My Saeco magic deluxe needed the circuits relaoded. I followed the intructions and now my machine tamps first and then grinds the beans leaving me with weak coffee can anyone solve this for me ?
try this.
hit the external dosage button. Its the button on the top middle that controls when you want to put grinds in from the external shoot.
Do not place any coffee in there. then just press the normal brew button. it should brew more or less a cup of water.
then try brewing a coffee like normal and see if the problem fixes.
this happens because there is a little door in the grinder that hits a microswitch that tells the grinder to stop grinding.
This is supposed to happen when the grinder fills the brew group enough to click the microswitch.
Sometimes it does reverse itself like this.
The only other solution would be to open the grinder up and vaccum all grounds out and vaccum the grind shaft above the brew group on the side.
This will cause the door to go back to normal position.
If it doesn't work after that, the door or microswitch has gone faulty. But that is an extremely rare situation.
Hope this helps.
Oct 03, 2009 | Saeco Magic De Luxe Espresso Machine
Grinder won't stop
Hi
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
DGB-900 Grind and Brew grinder
One idea to try. I noticed with my grind & brew that the moisture never evaporated from the inside top of the machine. Since that cannot be good over a long term, I have started leaving the top open during the day after I clean the machine in the morning. Your problem is why I started doing that. Why don't you try leaving the top open for a couple of days and see if drying the machine out doesn't cause some of that gunk to dry out?
Feb 22, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Water in the waste unit, coffee comes not strong enough, as use to, although the settings are for strongest possible and the coffee grinder is set to medium. My unit is 4075 but I think it is just the...
Your chute between the grinder and the brew unit is "glued" with coffee. Take out the the brew unit, clean it under water. Take a vaccum cleaner and put the pipe into the hole where the coffee falls into the brew unit. Move the bean container "hard" in and out ( knocking inside the maschin to loose the blockage). Switch in the main menue all to factory defaults. Put the grinder "level" into the middle again. start a brew unit cleaning process. After that you coffee must be ok again. Do not use oily beans or coated beans. the block the chute.
Mr. Cool
Sep 30, 2008 | Miele CVA4070 Coffee Maker
Saeco vienna Deluxe grinder doesn't work properly
Try to open the steam knob and make a cup of water.
Make sure everything is in place.
One more thing you can try is:
open the door, take out the brewing unit, driptray and dregsbox.
Look in the machine and you will see three hole, one in the lower left corner, one in the middle above the driving shaft and one in the right upper corner.
Turn on the machine and put a screwdriver in each hole and see if the lights go off.
Hope this will help you.
/Mirran
Sep 02, 2008 | Saeco Vienna De Luxe Espresso Machine
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
277 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
