Question about NetGear DG834G Router
Netgear DG834G unable to connect
I have set up router and USB adaptor. My computer (vista) finds the router name, but when I go yo connect bottom right tray windows can not connect. I have only loaded driver for netgear as advised WG11V3 dongle as I was fed up with netgear wizard appearing at start up. I then had to go into programs to start it up. All I want is to be connected at start up with no wzards appearing. I have 3 lights for signal. I have not entered my connection passphrass anywhere yet as windows has not ask. Please can some one help
Regards Russell
  • 34 Answers
Usually you have to use the software on the disk to open your web browser to http://192.168.0.1 or http://192.168.1.1. Then you can enter the administration username and password to change the settings.
Posted on Oct 10, 2008
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
How to connect laptop to netgear wireless-g
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
May 18, 2010 | NetGear DG834G Router
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
May 08, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Just got a new ipod touch when i try to connect to internet it says unable to join the network netgear. i have a neatgear dg834g router
router
that computer.
Click here for step by step instructions
Jan 16, 2010 | NetGear DG834G Router
I have already connected to my Desktop DG834PN router, I wold like connect my WPN 111 USB 2.0 Adaptor to my new Laptop. Please can yoy help me without any charge. Suresh.U.K
plug in the usb adaptor in ur laptop and it should detect the wireless signal one detected give it ur private key and ur done
Jan 10, 2010 | NetGear DG834G Router
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Configuration for wi-fi
Yes its possible! first thing you need to do is call your ISP and ask what kind of connection type you have for your service then if your connection type is static connection yo need to ask for IP information regarding your service this is the connection type you need to set in your router, now if your service is Dynamic connection or DHCP you just need to hook up your router and set it to dhcp . i believe most router is set to dhcp as deafault settings so all you have to do is hook up you internet connection to your router. if your still having problem with your router you can call your router vendor support number, just give then your connection type and they will guide you regarding the router settings and how many computers you want get connected.
Nov 09, 2008 | NetGear DG834G Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
299 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
