Question about HP DesignJet Z2100 InkJet Photo Printer
HP z2100 horizontal lines where the text or object are
When priting a picture, the priter works great. When for example adding text on that picture, the print is already not ok. What happens is, that at the end of the text (same size) I get darker tone (like shadow).
This goes all the way to the end of the print. These lines are also if I add some object in corel for example. But when printing picture without anything added to it, the printer works great.
Any idea?
    Master:
  • 788 Answers
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Posted on Oct 08, 2008
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Why is my printer 7310 all-in-one omitting last line of text when printing
mabe you are printing on the wrong paper size: Your text is set on A4 and you are priting on a letter sized paper.
May 19, 2015 | HP OfficeJet 7310 All-In-One InkJet...
Taking long timeto swith on the printer
try clearing all previous jobs from t he hard drive- it only does File System Check when a corrupt file has been identified on the hard drive and so it is re-writing all the information from the eerom back to the hard drive ( usually a sign of a failing hard drive) suggest you order one on-line ready for replacement. (you will need a HP Z2100 hard drive from HP a standard Hard drive will not work without some tricky copying/backup proceedures.
Dec 14, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Horizontal Lines through the photo
Horizontal may not be due to the CCD sensor. It can be due to the lens itself. I swap lens from a non-working camera to replace the one with horizontal lines. I found out that I was able to get the camera to work to take great pictures.
Sep 07, 2009 | HP Photosmart M537 Digital Camera
How to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
Jun 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
White line through printing about 30mm apart when in draft text & text/pictures ok on photos [both settings] have cleaned heads but still problem exists
HP Officejet Pro L 7680 All in one printer prints with a white line running horizontally through all the letters.
Can anyone help?
Thank You,
Alfred F. Marton
marton@san.rr.com
Aug 15, 2008 | Office Equipment & Supplies
Pictures looks 3D-ish with small horizontal lines
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP DesignJet Z2100 InkJet Photo Printer Logo
381 people viewed this question
Seeker5211
Seeker5211
