Question about Compaq Presario X1000 Notebook
Doesnot enter standby mode and hibernate mode
Dear, i have note book presario 2500, my note book does not enter standby mode and hibernate mode, i already change the bios to KH.F 22 and KH.F 25 but problem still happen, hibernate setting and power option already check but it's still same, thanks for attention
  • Daniel Herd
    Daniel Herd May 11, 2010
    have you tried manually asking it to enter standby or hibernation or have you only tried closing the lid? this is important because it could determine if the problem is software or hardware based. Also, when you close the lid does anything happen (lights, sounds, screen flickers, etc)?
    Problem Solver:
  • 7 Answers
Hy quick fix go to the web sit and get updates on all mother board soft wair and go 2 my computer propetys and check se if thay are any yellow highlights you will be able 2 solve that way2 good luck plumdj
Posted on Jan 14, 2009
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
or
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
or
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Laptop not stand by
Please press the power button once. It should go in standby mode.
Jun 08, 2009 | Dell Latitude D600 Notebook
Re move hibernation mode
press the power button for ten to twelve secons and it should reset
Mar 24, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario
Right-click your desktop and go to Properties (Note: Don't click an icon, just the background image of your desktop). Afterward, click the tab at the top of the new window labeled, "Screen Saver." Now at the bottom of the Window select, "Power." Now change the settings so that the system doesn't turn off the hard disks, enter standby mode, or hibernate. Afterward press OK, then Apply, then OK again.
Let me know if I can help you further, or if I need to describe any of the above instructions in more detail.
Mar 22, 2009 | HP Compaq Presario SR5610F Desktop PC
Presario 2500 notebook boots up only to hibernate
Sounds like a poor power connection on the motherboard. Unfortunately, this isn't an easy fix - you have to completely disassemble the laptop and resolder the power connector. To check and see if this is the case, you can plug in your laptop, set it down on a table(so it doesn't move or get bumped), wait for it to start booting up, then gently wiggle the power cord where it connects to the laptop. If the computer shuts off, then it is, in fact, a loose connector.
Feb 13, 2009 | Compaq Presario Notebook
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Inactive standby option
>I saved myself from a lot of these problems. I set the power button on the front
>of my computer to put my PC into hibernation.
>This is how you do it:
>1. Go to the Control Panel
>2. Open the Power Options window
>3. If Hibernation isn't on, go to the "Hibernate" tab and turn it on.
>4. Once you have hibernation on, go to the "Advanced" tab.
>5. If your computer supports it, there should be a dropdown menu in the "Power buttons"
>area. From there you can make your computer perform a lot of power management functions
>including Standby and Hibernate.
[Reply or follow-up to this message]
Jul 10, 2008 | Microsoft Windows XP Professional
Sleep mode
Depends how it is set-up. If it is just in standby then simply moving the mouse or pushing a key should work. If it is in hibernate, then you have to push the power button for it to power back on.
Jan 08, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Compaq Presario X1000 Notebook Logo
169 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
