When the computer boots up the fans start but i can't get a signal on the monitor and the computer does not beep
  • cr4t5 Jan 02, 2009
    Similar Problem. Installed new 1G DDR2 PC5300 RAM. Upon power up, monitor did not come on. Cycled monitor power, monitor shows No Signal. Swapped RAM for original, same problem.
    After a few minutes, computer beeps 3 times.
    Gateway desktop, Windows Vista.
    Master:
  • 788 Answers
There are many possible reasons for this. You best bet for troubleshooting is to get the computer to a minimal configuration. Do this by removing all add-in cards, unplugging all drives (CD, Hard drive, Floppy), remove all memory modules but one. If the PC boots then add one device at a time until you find the one that is causing the problem. If it doesn't boot in it's minimal configuration then either the RAM you left in, the CPU, motherboard, or power supply is faulty. I would bet that it's either the RAM (try a different module), or the motherboard. If it's not the RAM (no modules work), then your best bet is to test with a known good power supply. If that still doesn't work then it's either your CPU or motherboard, most likely the motherboard, CPUs don't fail very often. Good luck!
Posted on Oct 08, 2008
  • 49 Answers
- You need to reseat all of your hardware inside the system like hard drive power and data cable,as well as the dvd drive cable, reseat also the video card and power supply cables. Make sure that you will tigthen the video cable screws. after this step- turn the system on.
-If the monitor does not response from anything, try using different monitor so we copuld isolate the issue.
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
I'm having an aspire m5640. it does not boot. beep?
Yes if there are error on the system you should most likely hear a beep most of the time when there is no beep it is due to bad ram. Some times beep codes can't detect bad ram and your computer will not boot.
Open the computer up and see how many ram chips you have if you have more than one take the one in dimm slot 2 out. There should be small writing next to the slots 1,2,3,4 or Dim 1 dim 2 ect ect. you always want to keep slot 1 with ram so start by pulling out the ram out of slot 2 and turn your computer on. If your computer still dosn't post pull the ram out of slot 1 out and insert the ram that was in slot 2 into slot 1 if still no luck it's most likely your board but the best way to test this is to know that you have a good working stick of ram you could purchase one and if it dosnt work bring it back ... theres also the chance of your video card being bad but there is usualy a post code for it (beep code)
if you have no clue on what ram looks or how to open your computer just google for installing ram on a computer and you should find step by step guides
Jun 02, 2010 | Acer Aspire m5640 PC Desktop
No signal to monitor. No beeps at start up. Fans running. New video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
There might be a problem with your RAM you may check your RAM and clean it with a cotton cloth and fix it again or change your RAM and see
Or the problem can also be with your moniter
thanks
May 14, 2010 | E-Machines eMachines Desktop PC
Pressing power switch, computer green light below power switch does not come on; fans run; dvd player drive blinks; no boot up. monitor says no signal.
Does the computer Beep at all. If it does, and it beeps differently now than it did previously then that is a POST code and indicates a serious problem. If it Beeps like it used to but there's no video then you should still hear the hard disk clicking - that would be a Video card problem (or perhaps the monitor). If it doesn't Beep at all and it does not make a clicking noise then your BIOS, or Motherboard may be damaged.... perhaps by a failed, or faileing power supply (?)
Feb 17, 2010 | Computers & Internet
The desktop won't reboot. The power light stays yellow. I hear a fan running, but the monitor says no signal.
If your fan runs and the hard drive spins up, then you have a video card problem.
I'd do this: Disconnect everything inside the case but the CPU, memory, and video. Now try to boot. Also observe the fan on the CPU--does it spin?
If this fails, then your video has probably gone bad. Also--does your computer usually give you a "beep" when it starts up? If so, is it giving you a beep now? If not, you're failing the hardware startup test (POST).
So, your problem may be the video card. If your video is part of the motherboard, then you need to replace the motherboard.
Oct 01, 2009 | Computers & Internet
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
T1150 emachine Computer not booting up correctly
did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Nov 29, 2008 | E-Machines T1150 PC Desktop
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
89 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
