Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Dualshock 2 L3 problem
The L3 seems to be stuck on forward position. All the other positions work, but when i let it go it seems like the forward one is still on. Is it getting old?
  • Hunting Poer Dec 07, 2008
    I've same problem, L3 Or R3 seem to get loose by itself suddenly. However they're either brand new original controller or just played for awhile. Is there anyway at all to fix it (other than to buy a new one)
  • 98 Answers
It seems as if it is old and could be caused from pressing down on it to hard.
Posted on Oct 11, 2008
My 2000 olds bravada glove box door is stuck open the latch won't let me close it. Even though there is no way to lock it it seems locked! Do I need new latch or can I fix this one?
Your latch might be in the closed position before you even close the door, try using a small screwdriver on the latch while pressing the release button, if it's stuck closed then this will open it to the right position so it will lock closed when you close the door. If this does not work, sometimes the problem is in the striker (the little tab that the lock hits when the door is closed, this usually has 2 small screws holding it in place, you should be able to loosen both screws & adjust the striker forward or backward so the latch will make better contact with it.
Jan 06, 2015 | Cars & Trucks
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Craftsman lawn tractor will not engage in forward drive why
Check to see if brake lever is stuck on trans, keeping the brakes locked. should not be any squalling noises. Also make sure belt is routed right. and all idlers spin free.
Feb 01, 2018 | Craftsman Garden
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
Sunroof won't move back in response to the back button
faulty reverse switch or dirty running tracks
Mar 01, 2017 | 2005 Saturn VUE
Message reads error Press I. code 07.010.43:94437, can you please tell where the problem occurs.
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
1 Reboot the printer.
Did this correct the problem?
2.Do the Printhead Restraints rotate
correctly? if no. then Repair or
replace the
Printhead
Restraints.
3.
Has ink spilled ink around the Printhead
that prevents the Printhead from moving
to its center position? You should be able
to push the Printhead right to left. Make sure the printhead area is cleaned.
4.Is the Printhead stuck to the Wiper Blade?
Start the printer in diagnostics mode and run diags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5. Does the X-Axis Motor drive the Printhead
to its center position (so it can tilt forward)? if not
Troubleshoot
the X-Axis
drive.
Well hope this helps.
Nov 09, 2009 | Xerox Phaser 8400 Laser Printer
Electric front seat stuck in forward position. It's a 2002 Camry. I moved the electric adjustment completely forward looking for an item and it would not return back to the original position. Both tilts...
I had the same problem on my 2003 Toyota Camry. The threaded drive screws are what spin underneath the seat and cause the seat to move back and forth (same way a garage door opens or closes). When the seat gets all the way in the forward position, the threading on the drive screws ends, which causes the bolts connected to the seat to jam and get stuck. It should sound like the motor is trying to turn but it won't, it just clicks. Un-jam the bolts and rotate them one rotation from the all the way forward position to ensure your seat is reinstalled straight.
Oct 27, 2009 | 2003 Toyota Camry
SHARP 1631 CODE L3
The error is for the scanner mirror home position sensor. When the scanner mirror comes back to home (start) position if the photocell sensor doesn't see it due to be dirty or faulty the L3 error will be displayed.
Hope that helps you.
Aug 04, 2008 | Sharp Office Equipment & Supplies
Lens stuck open position
The internal gears or parts may be damaged beyond repair.
You may want to sell it as parts on a site such as Ebay. List in the title:
as is, parts, repair parts, or repair.
To fix such a camera would be more than it is worth, in my opinion.
Take care.
Jun 25, 2008 | Nikon COOLPIX L3 Digital Camera
Lens stuck in the out position
Please reload the Firmware and your problem will be solved.
Nov 23, 2007 | Nikon COOLPIX L3 Digital Camera
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
190 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
