It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
can i suggest you kill it !!!!!! sorry but there is a draw on the battery ,,,, disconnect each item one at a time till battery dont spark at lugs when you disconnect them ,,, seriousy loossen lug on battery and if no power draw no spark wil be present... maby alittle one cos radio takes a really small current
a possible battery or charger problem. check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it. but if you can charge w/a diff. battery?replace the battery. :)
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
