FixYa.com
Tags:
Top Motor 50x50x20mm DC 12V Ball Bearing Fan Fan Kit
93 Convertable top problem (by 2 users)
By Mini Me - usenet poster
Today the top would not go up.
Could hear the relays clicking.
Tested the relays, connection to motor, and wiring.
Cleaned with contact cleaner, everything looked good.
Still no top, motor won't make a sound.
Checked all fuses. Bought the stang used and do not have a manual. I
may have missed the correct fuse can anybody help on this one?
Stange thing is that if I check the voltage to the motor, while holding
down the switch so the relay is energized, I do not get 12v on the motor
connection, I would think I should. That's why I wondering if I missed
the fuse for the motor.
Please help.
Steve
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 28, 2007
saab 93 se top work,t fine,tried to open it and nothing no warning on dash etc any help
Best Solution
posted on May 26, 2006
Helpful (85)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is a seeming to become a common problem with the rams in the 94-up.
They are loosing the seal on the shaft and
shooting the fluid everywhere.
The rams are not that hard to replace.
You must remove the bottom section of the rear seat,the interior quarter
panel,and the vinyl cover over the motor/pump assy.
The ram is held on by a torx bolt on the shaft side and in order to get to it
the top must be about 1/2 way down.If you do it in a garage,a bunjy cord
attached to the top and roof/garage opener works great to keep it at this
height.The ram body is held into place by a single nut and the whole thing will
drop right out.Be VERY carefull
with the fittings on the ram as the body is aluminum and very easy to cross
thread when putting line on new one.After installing new ram,lift the
motor/pump from its bracket and tip on its side (can put top all the way up at
this point) and remove the rubber plug in the end of the pump and add
either ATF if the original fluid is pink or Hydraulic oil if clear (I have seen
both used in these) raise and lower top several times to get air out of
lines,add fluid till loud growl goes away.If too much fluid is added it will
push rubber plug out,if not enough it will growl loudly.Replacement time is
about 1-1 1/2 hours.To remove seat bottom you will need to insert a screw
driver into a latch
on each side of the seat right at the floor and push in,this will release latch
and you will be able to remove seat bottom.
MUSTTANGUY@AOL
95 Mustang conv.v6,chrome17"s, dual exh,fogs
91 Mustang conv,95 run'n gear,GT40,orig.cobra body kit,modified
87 Mustang GT,for sale
82 Mustang GT,future BB
86 Ranger 4x4,9"lift,33's,91 5.0 going in
92 Bronco 4x4,7"lift,35's,winch,35
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
On 16 Sep 1999 15:40:27 GMT, (Musttanguy)
wrote:
Wow! What a great set of directions. Makes me think that even *I*
might be able to handle this one. Though I'll probably wait for a day
when my husband is around with an extra set of hands *just incase*.
LOL! Thanks for taking the time to post. I appreciate it.
Juliet Pageoverlooking Mill Creek on the Chesapeake Bay
mailto:
Solution #3
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
Other possibility is failure in the hydraulic system which does the
lifting (if the '93 has the same lift mechanism the '95's that is).
My 95 blew a seal on the right side hydraulic cylinder at about 55k
miles. Heard the clicking and the motor whirr. Top didn't go up.
Instead I found all sorts of nasty hydraulic fluid squirting out of
the top of the cylinder where the piston goes in and out. Make sure
you clean that up since it's caustic and will eat paint in a
heartbeat. My ford dealer wouldn't work on it (Koons in Annapolis,
MD) and sent me to a local shop which does custom vans & upholstery.
Paid $350 to have a new hydraulic cylinder installed. Worked for 10
days and the left side died. I was NOT a happy camper. I'm not
spending another $350 on this car right now. :-( So I manually
muscle the darn thing up and down. '
Has anyone attempted replacing the cylinder themselves? How much of
the interior must be disassembled to get at the guts of the thing? Is
it easy to get the fluid back into the system? I'm thinking of
selling this car to get a '69-'72 Red Corvette Convertible with a 454
instead. Only thing holding me back is lack of a backup car - which I
won't have unless I pay off the Mustang beast first, which then makes
a vette payment impossible. No way will I park a vintage vette at the
University student lots, or drive it in the snow / salt.
mailto:
Come join the PictureKnits list on Onelist.com
Solution #4
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
If you can hear the relays clicking in both the up and down position you have
power up to this point.I would suspect the motor
has failed as they are notorious for this.
MUSTTANGUY@AOL
Can you Help with these System Cooling problems?
System Cooling
damaged printed circuit board...
I don't think I'm in the right... Answer This...
System Cooling
Air Condition
Ac only works for a minute or... Answer This...
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
