Question about Dell 1700 Laser Printer
Dell 1700 laser - loud noisy, grinding sounds
Hi! What can be causing a loud noisy grinding sound when my Dell 1700 laser powers on and also when I print the first page, or it has been sitting idle a while? What can I do about it? I've taken out the toner cartridge and drum and put them back in. They seem to be well seated. I'm afraid this grinding is wearing and ******* the printer.
  • Anonymous Feb 01, 2009
    My printer is howling like a wounded moose!
5 Suggested Answers
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Posted on Jun 06, 2008
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
SOURCE: Dell Laser printer 1700
what about my 1700, I've tried several port cables, different computers, all lights are ready and the thing won't print. Paper and toner good.
Posted on Aug 07, 2008
Corysf62
  • 188 Answers
SOURCE: Won't print dark black; prints in gray
There are a few possible causes for the light print.
The first is the easiest to try and least expensive.
If you actually had a bad toner cartridge, and the toner was not making its way down the toner tube to the developer, then you may be able to fix the issue by simply doing a developer cleaning on the black developer. What this actually does is force aggitator to move toner down the tube into the developer. You can activate this from the maintenance menu.
If this does not fix the issue, then more then likely the black developer unit itself is defective and needs to be replaced.
Posted on Nov 13, 2008
  • 85 Answers
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
Printer not recognized by XP Says needs the software
HI,
I'll give you the drivers for XP in a moment.
Dec 10, 2008 | Dell 1700 Laser Printer
Dell 1700 printer doesn't pick up paper - have reversed the rubber rollers and still isn't picking up
It sounds as though the rollers are needing to be totally replaced. There are other rollers as well and pickup pads that need replacing after awhile. I suggest taking it to a Lexmark dealer as the Dell and Lexmark printers usually take similar parts. They may even sell you the parts to replace yourself if you know what you are doing.
May 27, 2010 | Dell 1700 Laser Printer
My Dell 1600n scanner function does not work properly. When the scan mechanism attemps to move there is a loud gear slipping / grinding sound. The scan mechanism moves only slightly. Is this something I...
sounds like your csanner is locked.up under where paper comes out look for a blue lever and pull towards you to unlock scanner.push in to lock scanner.check with printer off.
Mar 12, 2010 | Dell 1600n All-In-One Laser Printer
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
Loud grinding noise. Paper only coming half way out then getting Jam notice. Loud grinding is very loud.
Hi
Grinding noises indicate either gears that are self destructing or something is stuck inside. Take out the cartridge(s), remove the paper and all the plastic that comes off. Unplug the cables. Now lift the printer, turn upside down and shake. If there are broken gears a local repair shop might try to fix it but most stores refrain from this.
Aug 05, 2009 | Dell 1600n All-In-One Laser Printer
System shuts down when printing to dell 1700 laser printer
You may have a 'recalled printer' Check out this link!
http://support.dell.com/support/batteryrecall/index.aspx/en/main 1700/1700n Printer RecallIn cooperation with the U.S. Consumer Product Safety Commission, Dell is voluntarily providing the Customers who purchased the 1700/1700n printer (from June 8th, 2004 - August 18th, 2004) a free replacement printer. [Announced September 7, 2004]
May 11, 2009 | Dell 1700 Laser Printer
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
No spin and laser grinding on the rail!
Call Sony Canada as soon as possible as this could scratch and ruin your games before you know it!!!! The Help/Support Number is toll free. It is: 1-800-222-7669
Mar 07, 2008 | Sony PlayStation 2 Slimline Console
Makes loud sounds
I had the same problem with the loud grinding sound. The gears on the cartridge(s) is not turning but rather stripping creating a grinding sound. Reinstall all of the toner cartridges. If that doesn't work, pull each cartridge out and manually turn the gear on the cartridge. If the problem persists, you may need to purchase a new toner cartridge.
Dec 04, 2007 | Brother MFC-9420CN All-In-One Laser...
Dell 1700 Laser Printer Logo
106 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
