Replace LCD for Presario C502US Laptop.
I have never taken apart a laptop and would like to know if it is difficult to replace the lcd in mind. Where can I find instructions ?
    Problem Solver:
  • 5 Answers
I can give you some general advice. I haven't worked on your particular model, but I can help guide toward what you want to do. To remove the LCD screen, you have two main goals: 1) disconnect the signal cable and 2) remove the LCD screen at the hinges. Depending on the model, you will need to remove the cover between the keyboard and the hinges, the hinge covers, and perhaps the keyboard too. The ribbon cable that connects to the LCD matrix is under that cover between the keyboard and the hinges. The cover also covers up the screws for the hinges. Get to that LCD and unplug it first; then remove the screws for the hinges. The voltage inverter that jacks the +18 volts up to +600 volts for the screen backlight is usually either under the cover above the keyboard or behind the bezel beneath the screen. Good luck!
Posted on Oct 08, 2008
How to replace the lcd on a compaq presario CQ60-615dx
Here is a website with step-by-step picture instructions on how to replace the lcd on your particular model of laptop.
Thanks, and have a great day!
Oct 03, 2011 | Compaq Presario CQ60-220US PC Laptop
How do I replace the lcd screen on a cq61
You will have to contact HP and request a repair. Screens are difficult to replace and you could damage yourself and the laptop if you don't know what you are doing.
Mar 05, 2011 | HP Compaq Presario CQ61420us Notebook
Hi! I believe I need to replace the C Mos battery in my compaq presario C502US laptop. Can you tell me step by step where I find it and how to do it? Veronica
The best option is to contact HP they will direclty provide you with the steps..
First contact them and then rate me if I was correct or not...
I am sure they have the steps..
Jun 25, 2010 | HP Compaq Presario C502US Notebook
Need help with a Presario c502us laptop that will not start.
You are wasting your time. Bad motherboard.
A1 Elmbrook Electronics Inc.
Mar 30, 2010 | HP Compaq Presario C502US Notebook
Compaq presario c502us laptop how to enable the administrator account in the system recovery options
Hello and thank you for using Fixya's services.
You cannot use the administrator account. You can however, use the drop down menu to select your user-name. Typically, you have the administrative rights and will be able to restore successfully.
Please let me know if you have any questions.
Nov 03, 2009 | HP Compaq Presario C502US Notebook
If you have never taken apart a laptop before, find someone who has.
It is fare to easy to brake the new lcd or but a wrong screw in bazel cover and brake more than what was broken.
Sep 11, 2009 | HP Compaq Presario F750US
Lines on laptop
If the lines are like static black stains, then that is a faulty LCD panel, with a liquid crystal leak.
If the lines are colored , and come on when you turn on the laptop, that is a problem with LCD ribbon cable or connector, or a broken connector on motherboard or LCD display.
Either the LCD display, or the ribbon connector must be replaced.
To do that you need to take apart the laptop, the repair should be done by a technician.
Jan 22, 2009 | Compaq Presario M2000 Notebook
Compaq Presario Laptop (M2000 series) hinge
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
Aug 18, 2008 | HP Compaq Presario V5000Z Notebook
Dropped laptop
The symptoms you describe can be a damaged LCD, but they can also be caused by a loose LCD connector. If you are comfortable opening the laptop case, it would be wise to check this first. Sony uses standard Torx screws, if you buy the right size, taking it apart is not too difficult. Just do not FORCE anything. Be very patient, careful and gentle. Work in a space where you can capture any parts that drop and organize all the screws/parts in the same pattern they were removed. Then you find the ribbon connector (usually brownish-orange in color) and check the seating at both ends. If the laptop was OPEN, meaning the lid/LCD was open when the laptop was dropped, this ribbon might even be torn, and need replacing.
Feb 11, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
