Question about Acer AL1913W 19" LCD Monitor
Monitor won't turn on normally. Possible Inverter problem?
I have had an Acer AL1913W for a few years and when I first got it, I had to send it to get the inverter fixed. It's worked fine since then.
A few days ago I cleaned the monitor through the vents with a really powerful jet of air (don't know it's the cause or a coincidence) and now if I leave the monitor off for a few hours, it won't go back on. It sort of stutters to go on and then goes black but I can still see the image with a flash light. If I turn it off and on a few times, it will eventually light up and will stay working. It seems it needs to warm up first. If I leave it on (with the black screen) for a minute or two and then turn it off and back on, it turns on immediately.
Could I have knocked something loose inside with the air? Any ideas what to check inside to see if something needs to be replaced or fixed?
  • wwfmike Oct 12, 2008
    Is there any way to check and see if they are still good?
    It wasn't a can of compressed air, I used a vacuum cleaner on reverse and it gave a pretty strong blast. I think it messed up my dvd-drive as well.
    Would it be overheating if it doesn't go on after being off for a few hours?
    Novelist:
  • 159 Answers
Not likely that you knocked anything loose.
Keeping it clean is a good thing and helps stop overheating of parts.
Power should be unplugged when doing this. There is a slim chance if using canned air that at times liquid (usually freon) will come out and could cause a temporary short.
Ironic thing is: Overheating is what yours seems to be doing.
The capacitors on the powerboard or inverter are more than likely starting to fail from heat and age and should be replaced before it gets worse and eventually burns out a part that is harder to get and harder to diagnose.
bammbammfran
Posted on Oct 11, 2008
I have v193w acer desktop lcd screen suddenly it went black the blue light (( which mean that it's on and every thing works fine )) is on all the time but nothing appeared like the the screen is completly...
Ive had that problem recent, same monitor. Same months to be exact, though started around October 2010 then got worse. Do not send it back to Acer, I did and the cost was 20 bucks to ship to them and all I got was a note and monitor back saying they tested and then did Extended testing and found nothing. Not even had it for 1 year or 2 years to say, 3 year warranty. Just going to buy a new one and perhaps a LED from ASUS, the V stands for Value on Acer website, guess I got what I payed for. Think it was $166 I payed for this thing. It is shame, as its nice monitor but I cannot have it not trusty like this, cannot even play some games without it going off like this. Worst if I put the monitor in Graphics or Movie mode makes it worse it seems.
Nov 04, 2010 | Acer V193w LCD Monitor
When I turn on the monitor the green power light comes on and stays on, but the screen flashes on and of as it tries to light up and a clicking noise can also be heard. This happens every second or so...
Look for bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 17, 2010 | Acer AL1913W 19" LCD Monitor
NdLouSpence@msn.compowers up with green light, but a black screen, it takes a few attempts turning it off and before the screen starts, then ok no problems
You may have dying power supply problem due to bad caps, that will be the first place to check.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 16, 2010 | Acer AL1913W 19" LCD Monitor
Acer monitor won't stay on
That looks like an inverter problem. If the monitor is still under warranty, contact the manufacturer (3 years for both parts and labor if purchased new). Otherwise, open up the back of the monitor and remove the shielding. Look for scorch marks, soot or leaking or bulging capacitors (look like cylinders on tripods). You could just replace the capacitors and the resistor that acted as a fuse. However, for $50-150, depending on the inverter, you can replace the entire part (unplug the wires for the backlight(s) and other connections and swap them).
You can also check the inverter by looking for the high frequency EM put out by the unit. Some high end multimeters will measure this (as will an oscilliscope). Hold the multimeter probes a fraction of an inch apart about an inch above the board (with the multimeter set to read frequency). If the inverter is good (and the frequency is reasonably close to the multimeter's range) you will see either a 1 or a value (kHz). If the inverter is bad or too far out of range, you will see a result near zero.
Once you have the monitor open, record the part number on the board with the damage, including the REV number if any. Search that part online (lcdparts.net and other sites have parts for monitors). Get the correct unit if possible. Some sites sell universal inverters and those can be used. However, you may find the controls reversed (up to lower brightness).
I hope this helps.
(a backlight issue would have resulted in a slow fading of the image or the screen looking red/pink.)
Jul 05, 2010 | Acer 22" X223w LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Acer al1711
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Nov 07, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Weird LCD Monitor problem with screening not turning on.
Could I have knocked something loose inside with the air? Quite likely
Mar 28, 2017 | Rosewill R900J 19" Flat Panel LCD Monitor
22" ACER MONITOR QUIT
93vette,
Well...what you need it a new backlight inverter. Your old one it's busted. If you got less than a year... you've got 3 yrs warranty on parts. Contact Acer asked them to send you a new inverter... Have a nice day!
Oct 05, 2008 | Acer Computers & Internet
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Acer AL1913W  19" LCD Monitor Logo
310 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
