Question about HP DeskJet 3535 InkJet Printer
My computer didn't recognize the printer, after a new harddrive was put in
Mourning
i have just connected a new hard drive to the computer, when the computer had recognizing the mouse, keyboard it didn't recognize the printer.
my printer is 18 inches long, 7 inches wide and 6 inches high which uses # 28 and 27 ink cartridge.
Need to download hp deskjet 3535 driver to Windows 2000/xp
Posted on Feb 15, 2009
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
My computer will not recognize the external harddrive so I can't access it
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Apr 10, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
IPod gen3 stuck in the Do not disconnect mode and the computer does not recognize it.
check the cable connection, for the hard drive that not recognized by computer, usually the problem is come from the cable connection not connected properly
Feb 22, 2011 | Apple iPOD 40GB Toshiba Harddrive for Gen...
My computer cannot recognise the hard drive
Are there any other harddrives installed on the computer...or is this a new harddrive...
If it's a second harddrive...then you have to set the jumpers accordingly...if it's a new harddrive...it should of came with a Cd and or floppy (depending on how old your computer is). You need to install that cd first, so it can tell your bios/cmos that there is a new HDD and the software will tell it to recognize it. Let me know
Dec 02, 2010 | Maxtor Hard Drive
Western Digital Harddrives // Win Vista two separate harddrives with same problem - once plugged in, lights on harddrives turn on, computer beeps but, doesnt recognize the hard drive. WinVista...
Uninstall the WD drivers, then, leaving the WD drives attached to the computer, reboot the computer.
Here is something else to try: Driver Booster by Iobit.
11 Free Programs That Will Help Update Drivers in Windows
And take a look at the software for your drives at the Western Digital site.
Aug 10, 2017 | Olympus Computers & Internet
I have ROCO 320 GB extranal hard disk which is not recognized in my laptop windows 2007. I had stored so many data from my desk top computer. Any solution please.
Connect your harddrive to another computer like windows xp then if it is recognize then take data backup . If your harddrive is fine then follow below for laptop. First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Sep 14, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Windows 7 is not recognizing and comes up as a cd drive?
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
External hard drive is not being recognized by any computer
then check.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
Computer won't recognize (Vista)
First of all make sure that the USB port that you are
using to connect it to your PC is a USB 2.0 port, and
not USB 1.0.
Also if it came with an external power, connect it to
the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is
lower than that of USB 2.0 and therefore might not
be enough to power up your USB Drive.
After making sure about this, power up your system,
and plug the harddrive, then Right-Click on my
computer icon, select manage, then go to Disk
Management Option.
On the Disk management option Page you should
see ALL the drives installed on your system,
including the hidden ones, so what you will just do is,
try and locate the one representing your harddrive,
and right click on it. then select "Change Drive letter
and Paths", and give the drive any new, unique letter
(i.e alphabet) different from the ones already on your
system, and click on OK.
This should make your harddrive to be detected
automatically.
Try this out and let me know how it goes.
Hope this helps you out.
Jan 02, 2010 | LaCie d2 Extreme (300790U) 250 GB Hard...
HARD DRIVE PROBLEM.
If the first drive will get recognized on another computer but not yours it would lead me to believe that the controller on your motherboard went out. But the part about the non os drive not getting recognized at all leads me to believe that drve went out. First i would definately take the drive somewhere to have the info transferred or if you can hear it spin up you might get lucky and it will work after you get your os to boot. it wouldn't hurt to have it backed up though. Before you do anything too drastic try to get your hands on another drive and see if you can get your PC to recognize any drives, if not then you will need a new motherboard.
Dec 23, 2008 | Computers & Internet
170 people viewed this question
Ben Johnson
