Question about Toshiba gigabeat S MP3 Player
Gigabeat room driver
Could you please advise where or how can I Download Gigabeat Room Software. I lost my CD and the Gigabeat room installed on my PC is corrupt, I couldn't open it.
Yes i need gigbeat room
Posted on Dec 10, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp ---------- try downloading the firmware again and installing it in your device click this link directly for firmware http://www.megaupload.com/?d=MO4S7T6I ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Oct 22, 2009 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Mar 30, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Cannot Instal CD for Toshiba Gigabeat F40 on Windows Vista
Download the MEGF Series Update 3 from Toshiba's website
Nov 10, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
No gigabeat room
hola formatie el gigabeat f40 y me aparese error de system porfa me puede ayudar mi correo es georamirez20@hotmail.com
Aug 20, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat Room
I've got the install CD that has gigabeat room 2.02 - US version. if someone wants it - email me the request and I'll email a zip of the whole CD. it's only 29 MB (kelly . piper . cherokee at gmail . com) remove spaces...
Feb 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat support is 1-877-250-8595
Sep 29, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba gigabeat S MP3 Player Logo
814 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
