Question about HP DeskJet 920c InkJet Printer
Hp desk jet 920c ink cartridge
Same black ink cartridge removed & replace, printer printed one page just fine then stopped printing any more pages...orange blinking light on and won't print.
Was it mistake to remove cartridge then put same on back in?
Last printed page was solid black...no gray.
help
  • 66 Answers
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Posted on Oct 29, 2008
My hp desk jet 9300 won't print black
Try replacing the black ink cartridge with a new one for starters.
Nov 04, 2014 | HP DeskJet 9300 InkJet Printer
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
HP 920c does not print color. I have replaced inks - color & black. When I switch mode to B&W only, all images and text prints. When i switch back to color, only the B&W stuff prints
Try reseating the color cartridge and cofirming that the blue/green tape was completely removed from the back and bottom of the cartridge. Run a head cleaning and if that doesnt correct it then you may have a bad ink cartridge. It is possible that the printer is bad but I find that unlikely.
Aug 31, 2010 | HP DeskJet 920c InkJet Printer
My J4680 only prints color, no black. Printer is
Your black cartridge is most definitely clogged. You can easily check that by removing the cartridge and press the print head on some tissue. If there is no mark, the print head on your black cartridge is clogged. Now, HP has some kind of software head cleaning. It doesn't always work, but you can try. Here is a link to HP site, referring to your problem: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361894&cc=bg&lc=en&dlc=en&product=3692888
Read carefully and follow the instructions.
If that doesn't solve your problem, you should buy a new black cartridge.
Also, bear in mind that with ink-jet printers, you need to print something at least once in 10-15 days, otherwise the print head will again get clogged and you will be facing the same issue over and over again. If you do not print on a regular basis, make some kind of test page, that contains black, yellow, magenta and cyan. Print that page once in 2 weeks and your printer will always work fine.
Apr 04, 2010 | HP J4680 Office Jet All-In-One Printer
HP deskjet 920C replaced both ink cartridges and now it prints in
When we see high page volume in these printers, the cleaning ink resorvor needs to be cleaned. It may be even to teh point of stopping the head cleaning carriage from functioning.
It sounds like it is not priming and wiping the head of the cartridges correctly.
You can also try setting the head of the cartridge on a damp warm (water wet) paper towel. If there is ink coming out onto the paper towel you know it is the printer not the cartridge. If you are not seeing any color then I would change the cartridges again.
May 12, 2009 | HP DeskJet 920c InkJet Printer
My printer could not print
Try installing the color cartridge. Some printers won't work if one of the cartridges is empty or defective.
Feb 27, 2009 | HP DeskJet 920c InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Wont print
Hi, yes I have had problems with these HP printers B4 and it was in fact the INK... strange as it may seem, Ya gota have them "Full" as it were. I have "Fooled" it sometimes by removing the cartridge(s) and powering on & of re-inserting them. But eventually always ended up paying thru the nose for the cartridges. I saved a bit by using refilled ones, but I now use printers that have cheap single color ones, eg: Canon i550
Jul 14, 2007 | HP DeskJet 920c InkJet Printer
Printing problems
Are you using remanufactured cartridges? If so, I would strongly recommend that you replace with factory HP cartridges.
Apr 17, 2007 | HP DeskJet 920c InkJet Printer
HP DeskJet 920c InkJet Printer Logo
217 people viewed this question
Ben Johnson
