Question about NEC Office Equipment & Supplies
Monitor going off but standby light still on, If i push the power button on and off quick i get a glimsp of the screen on but goes back to black screen and cant view it. Its NEC 1810 tft
  • antzrhere Oct 09, 2008
    Oh Didnt know they had a bulb :( are they replacable then ?
    Thanks for the reply
    Antz
    ok thanks very much for reply
    Antz
    Genius:
  • 2,120 Answers
Backlight bulb is burned out.
Posted on Oct 09, 2008
  • Leroy Elliott
    Leroy Elliott Oct 09, 2008
    I'm sure if you search eBay,, you'll find them.
    I've replaced a few, but they were from Samsung. It's not hard to do.
Black screen pushing red to green donot work do not hear any beep
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor)....
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Playstation is on but screen is black
Jun 30, 2010 | Sony PlayStation 3 40GB System
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
My screen will not power up. If I disconnect the current, wait a few seconds then re-connect - the standby light will go on. As soon as I try to turn on the computer - the standby light turns to green, a...
Hi rj05
I'm sorry to have to say this but you will have to take the monitor in to a repair shop. There is a definate hardware failure inside the monitor.
Regards
Go-Tech
Dec 15, 2008 | Computers & Internet
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
47 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
