Question about Hoover HTC243 Top Load Washer
The 7kg hoover will wash then stop agitating
Will wash for half the cycle then stop agitating but timmer will still be going
  • Hoover Master
  • 19,396 Answers
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Posted on Oct 08, 2008
Fitted new motor to a commander 7kg A6928 agitator spins but bowel stays still in spin setting why?
sounds like maybe a thrust bearing in the hub at bottom of agitator not engaging? are u saying the hub does not spin but the agitator moves?
Oct 31, 2014 | Hoover Washing Machines
My family 1600 hoover 7kg load wont stop its cycle and has been running for 2 days!!!!!!
hi, it sounds like the timer programme control could be the cause of this fault.also temperture control thermostat the heater and water inlet value are possibility hope it helps
regards
shaun
Nov 11, 2011 | Washing Machines
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
Oct 23, 2009 | Hoover Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Amana LWA40AL will not go to agitate cycle
Sounds like a timmer to me.. got a couple bad cycles too bad its the main cycle
Aug 16, 2007 | Amana LWA40A
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Mar 30, 2007 | Frigidaire GLWS1233A Top Load Washer
Hoover HTC243 Top Load Washer Logo
473 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
