Question about Polaroid FLM-2601 Television
Color on my screen the picture comes in red and blue, the menu option comes up in perfect color, what can I do to fix the color?
  • 4,234 Answers
This could be an problem external to the TV. What signals are you sending to the set? Does this happen with the internal tuner as well?
Thanks,
Dan
Posted on Oct 08, 2008
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
it sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
Mar 02, 2010 | Akai LCT2060 Television
I have a hitachi tv model number 50V500A the
go to the menu screen and select picture mode/menu and you should see the option to make changes to colors selection. You can also try and find one of your DVD's that has THX listed on the case. These DVD's have a calibration program included in the disc which can assist you with fixing the color issue
Nov 30, 2009 | Audio Players & Recorders
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Not true color
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Jul 25, 2008 | AOpen 19" LCD
Colors are off after auto adjust
Dec 05, 2007 | AOpen 19" LCD
Componet 1 and WII
First of all, make sure that you have the colors of the component cable matched correctly. You can switch the Pr and Pb cable and still get a picture although in the wrong color.
Secondly, go to the TV menu... the menu should still be in color. If it is in B/W then you might have a hardware issue. Try adjusting the custom color setting so that you get a blue picture or red picture. There is an option for adjusting the color called "blue mute" it should give you a perfectly blue picture. If you still don't get any color than it is a hardware issue. It could be the Main Board or the Control Board.
It was the Main Board in my case.
Oct 07, 2007 | Akai PDP4206EA Television
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Polaroid FLM-2601 Television Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
