Question about HP Deskjet 2460 InkJet Printer
Flashing led power button on deskjet d2460
Pressed print, printer took paper started printing for about 2 seconds,it then stopped and the power button led is now flashing irratically.
tried the usual power on & off, press and hold to reset etc.
have no manual so need some help.
  • 1 more comment
  • Sir Norman Oct 12, 2008
    HP Deskjet D2460. Light blinks continuously. I have put in new cartridges, cleaned contacts and cartridges. information strip, everything.
    Is it possible to re-set this.
  • Anonymous Nov 05, 2008
    I was not there when the problem originally occured. But now when i start the printer up the led keeps blinking on and off. I tried reinstalling the printer but that did not work. I'm going to give HP support a call and see if they have a solution
  • hifimts
    hifimts Sep 19, 2012
    I have a Hp Deskjet D2460 printer. When i switch on the printer the printer blinks led light contiusolly and printer is stop working and led light blinks continuous. Please guide me how i can resolve this issu.e
  • 34 Answers
Try to check your cartridges. Pull it out one at a time then try to see it it stop blinking. Especially cartridges that was refilled. Improper refilling of cartridges causes them to stop responding to your printer and causes to malfunction. this was base from my experience.
Posted on Mar 26, 2009
    Problem Solver:
Thanks adamzg for you contribution. However I tried something else and it really works, surprise surprise!!!! Anyone with this problem should try this-: I took the top casing off the printer and carefully removed the data strip (the clear plastic strip right behind the moving carriage). I cleaned this by wiping along its length with a soft cloth with just hint of water on the cloth. I was surprised at how much muck came off it. Replace it carefully making sure it passes through the slot correctly. Switched on and hey presto it worked much to my astonishment.
Norman.
Posted on Nov 17, 2008
  • 3 Answers
You have to look in the control panel for printers and faxes to get the status message for the printer. That will tell you why it's blinking. My printer seems to always be "jammed" even though it's not. It seems like there are some problems with the way the print heads track across the rail. It tends to jump really hard at the right hand extreme when initiating a move from right to left and then it says "paper jammed". Hitting the power button one time will some times eject the page. Other times I have to remove the back panel and pull the paper out the back.
Lather rinse repeat. I'm thinking of trying to return the thing on warranty but not sure if I have the receipt or will be able to return it.
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
If it is a Canon printer:
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Nov 16, 2010 | Office Equipment & Supplies
Error 2
HI,
THe error E2-indicates no paper error
othe error codes:
E22 Carriage error
E29 EEPROM error
Try resetting the printer,think this should solve your problem
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
RNJ VINODKUMAR
Oct 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MY MP160 FLASHES E AND # 3 ALTERNATELY
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
button pressing
procedures below.
procedures below.
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Troubleshooting HP Deskjet 2460
hp deskjet d 2460, the printer icon is missing . pl note that we need to operate the machine
Jul 23, 2008 | HP Deskjet 2460 InkJet Printer
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
1. Press and hold Cancel .
2. While holding Cancel , press On .
3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
4. Press Cancel again.
5. Press Copies .
6. Press Paper Type .
7. Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
4. When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
5. Reconnect the USB cable.
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Error code e-3
Mp150 Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Oct 02, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Stupid printer
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Sep 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Deskjet 2460 InkJet Printer Logo
5,152 people viewed this question
Ben Johnson
