Question about Microwave Ovens
I have a sharp carousel microwave, and the turntable has stopped, I just need an idea of where to start. I would assume it would be the motor, If I had a diagram i could work it out but I cant find diagrams for my model anywhere.
  • 958 Answers
Have you tried opening the housing of the microwave?
sometimes the diagram is pasted on the inner wall of the housing.
if you open it up, be sure NOT to turn it on without the housing in place. microwave produces high energy which could be harmful to us.
tnx 4 using fixya,
drcool
Posted on Oct 08, 2008
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Sharp Carousel convection/ microwave. The turntable/ motor coupling has broken where can I buy one? I live in White River Mpumulanga.My e mail adress is richardtaggart@msn.com
Looks like you have the purchase the glass tray in order to get the coupler. I would give Reliable Parts a call though phone # is 1-800-666-0313. Give them your model number and the name of the part you need.
Nov 29, 2010 | Sharp Carousel R530EST Microwave Oven
The carousel in our Sharp Microwave/Convection Oven suddenly stopped turning. Nothing seems to be blocking it--it whirls around when I push it. Any ideas?
Got someone to come look at it, and the motor for the turntable has burned out! We're ordering the part!
Thank you!
A.
Oct 07, 2009 | Sharp R930CS Microwave Oven
Sharp carousel microwave doesn't spin
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Nov 20, 2008 | Sharp R-408HS Microwave Oven
CAROUSEL STOPPED TURNING
Turntable motor req,Or drive shaft on top of this.
Oct 07, 2008 | Sharp R-1480 Microwave Oven
Sharp Carousel Model R-9H56
Check that the plastic connector from your motor to the turn table is not broken , mine broke and it took weeks to solve the problem. Try rotating the part that protrude into the oven. If you can turn it by hand it is broken, lucky cheap to replace
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
