Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Hard disk i/o error solution
i am getting hard disk i/o error how can i solve the problem tell me the procedure.............bye nice
Be sure the HARDDRIVE JUMPER is set in right place TO MASTER SETTING(If this is only harddrive you are using?),What bios options do you have?(BIOS AUTODETECT?),lastly what changes did you do B4 yu got this error?
Posted on Nov 30, 2008
  • OLDSCHOOLCAR Nov 30, 2008
    Ive had on some occasions to MANUALY RESET(Instead of using AUTODETECT)HARDDRIVE CYLINDERS-/-HEADS-/-And SECTORS THRU BIOS
Canon IR3300 Hard Disk Error e602 - 003
You need to have 20GB hard disk (IDE) and update the firmware thru parallel cable via SSST
Jan 10, 2014 | Canon Office Equipment & Supplies
RESULT OF SPACER PROBLEM IN CANON IR 3300
Hi This is Guru From India
I got IR3300 it shows the error message of e602 - 003,hard disk error,
I made diagnosis by pressing 1 and 9 at start,Still same Problem Continous!!
I need to reinstall hard disk , ,I Dont know the procedure,I dont have any manual for this will you please help to solve this problem, Please sent me the manual file , and service software to my mail ID : nagamguru@gmail.com, , There is no service engineer support for this in our place.
Thanking You
by
Guru
India.
Dec 18, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Computer no sound tells me no drivers .i got drivers unz ipped them .told the computer where they are located computer says none found go online and get some.maya 1010 says install hard ware (it has been...
Use a driver finder tool to download drivers for this sound card. Also scan your PC with a system utility tool like Reginout to fix wndows registry and missing dll files. After fixing errors install sound drivers.
Apr 29, 2012 | AudioTrak MAYA 1010 Sound Card
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
I have a 120GB external hard drive. it's saying that i have 111.78GB used and only 3.4GB remaining available. this is IMPOSSIBLE. for many reasons, but mostly because no matter what i do - including...
Thanks for using FixYa!
What you need to do is to format your hard drive. Go to "My computer" right click the hard drive.. then select format. Do not use the quick format procedure. This should solve your problem.
Have a nice day.
- HotRatchet
Aug 01, 2009 | LaCie 120GB Little Disk USB2/FW400 120 GB...
Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
Nov 22, 2008 | Office Equipment & Supplies
I want to increase the storage capacity my Hard disk.
hi,
You can use SATA hard disk.
you said you already have 40gb. so, your pentium 4 mother board can work with full performance with upto 80 gb.
My suggestion for you is to get another 40 gb and install it ,so it makes 80 gb as total.
Other option is , There are external hard disks available for reasonable cost. you can go for it.
Your RAM is ok too.
Hope my info helps you.
Bye.
Sep 25, 2008 | Computers & Internet
Compaq 5000 how to change hard drive
is a long procedure ......
if u available online than i can help u by telling u d procedure.....
i cant tell u now becaz if i tell u procedure n dere is some error occurs then hw could u solve it....so it is needed to be online both of them....
Jun 22, 2008 | Compaq Presario 5000 PC Desktop
Fan Error
Please contact the supplier for support under warranty.
If not under warranty, do check the power for the fan, after opening the outer case
Please disconnect the main power before opening :)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | NEC MultiSync VT540G Multimedia Projector
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
885 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
