Question about Jensen VM9510 Car DVD Player
Vm9510 it want load or eject nothing
  • oceanwind Oct 28, 2008
    My VM9311TS will not switch to DVD/CD mode or eject, load cd's or DVD's. No help from tech support except to pay $137 to send in to fix. But, I have to pay to uninstall it, ship and reinstall which will cost over $300. Does anyone have a solution for this or am I out of luck!
Unit will not cut off will not perform anything
Posted on Feb 22, 2009
No eject screen
Well, I have 2 answers for you. 1st, your
Dec 11, 2012 | Jensen VM9510 Car DVD Player
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
Six disc changer will not play, eject, or load. making eject noise nothing happens.
it sounds like the photo sensor has failed this unit detects disc and loads them if it blows it thinks it has a disc and will try to eject it over and over
time for a new stereo sorry
Jun 25, 2010 | JVC KD-G110 CD Player
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Jul 11, 2008 | Jensen VM9510 Car DVD Player
Repair dvd player dual audio
DVD / CD plastic housing breaks wear spring holds metal top pad to align CD /DVD on drive engine pad, most common problem.
May 15, 2008 | Jensen VM9510 Car DVD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
DVD Playback Error
here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
Feb 09, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
56 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
