Question about Hotpoint Washing Machines
Water goes out within 2mins of starting a washing program
  • 24 Answers
Is your drain hose higher then the bottom of the machine if not the water will just run out as it is filling. Please give more information if this does not help. Model etc.
Posted on Oct 08, 2008
Won't wash
If this happens within the first. 9 secs after filling it means you have a hearing fault
Mar 23, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
My washingmachine doesn't continue to the next phase of the program
Yes! it seems that the program controller unit is the suspect, but first you need to check with other set programs and see if the entire cycle goes through. If not this can be related to a processor gate failure to go into the next sequence.
Also check the water level sensor and the drain pump and push in all connectors to be fitting. MAke sure there is no moisture within or else you will need to use a dryer to clear off and check.
Jul 02, 2012 | Candy CBL160 Front Load Washer
LG WM 1437 At the end of a wahing program it starts detecting as if starting the program again, what is the problem
If the machine after completion goes back to start, then it is a fault on the main controller unit. make sure that there is no moisture on the panel or within . use a hair dryer to heat off moisture after removing power cord for a while.If not the controller is a suspect.
Mar 13, 2012 | LG WM-2277HW Front Load Washer
Wma11 starts to load water then goes to end program within seconds
hi try another program like spin cycle if is still the same the programmer timer control could be the fault
regards
shaun
Dec 05, 2011 | Hotpoint WMA11 Front Load Washer
Every time i turned on washer after 2mins into wash it will start to beep and the letter F will start to flash immediately the letter H will flash as well. It does not matter at what level or load I...
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Jul 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
Washing Machines Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
