Question about Lands Phones
My LG Dare's touch screen does not respond - Lands Phones
  • 5 more comments
  • Anonymous Nov 11, 2008
    not responding
  • Anonymous Jan 14, 2009
    screen doesnt respond to touch
  • GordonTarple Feb 27, 2009
    absolutely NO response from the touchscreen. all the side buttons work. i can ANSWER the phone with the call button, the camera works and I can unlock the screen with the button, on the side BUT screen does not sense touch... AT ALL.
    tried restarting the phone, tried removing the battery a few times, that didn't help.
    I've had the phone for 4-5 months so i'm very familiar with it, tried everything i can think of short of returning the phone.
  • Anonymous Mar 14, 2009
    Same issue as original thread. All "hard" buttons work and can unlock screen , but cant get any touch features to respond. In short all i can do is take a pic (but cant save or trash) and recieve calls. only can place a call if it was the last person that called me.
  • Anonymous Mar 21, 2009
    Same problem here. I was takein a pic and tryed to save it. No tuch feachers since.
  • Anonymous Mar 23, 2009
    WTFFFFFF
    MY PHONE ISNT WORKING EITHER O-O
  • Anonymous Apr 18, 2009
    IM SO PISSED I NEED A NEW ONE I CANT LIVE WITHOUT MY PHONE AND ITS BEING A ******** AND THE SCREEN WONT RESPOND TO MY TOUCH.
I had the same problem and from what I did, the screen is pressing against itself and is holding the position on the phone. I took a piece of tape and pressed it to the screen to loosen it. This is only a temporary fix and I will need to get a new phone today. This is a defect in older models (mine is from august) so they should replace it for free if you are stil under the one year warranty.
Posted on Mar 16, 2009
I ha dthis problem to. I had placed a hard cover on my phone and it push'e down on the screen holding the last place used. try removing your cover.
Frank DeHaven
Posted on Aug 17, 2009
As the screen is pressure controlled,there may be a leak on the it.
Solution
Gently heat the screen with the heat from a light bulb with low heat from it to get any moisture out of the screen.
It works.
Posted on Feb 09, 2011
Had the same problem too. I read this, tried the other solutions and they didn't work. Then I inspected the edge all the way around very closely because I was trying to figure out how to remove the touchscreen. Turned out, the last time I dropped it, the bottom edge separated ever so slightly. I pinched the bottom front and back sides and it snapped into place and the touchscreen works again. Hope this helps. This was stressful because I thought I had lost all my phone numbers and notes. Kept everything else on the SD card.
Posted on Dec 16, 2010
My LG dare will not respond when i touch the screen!!!:( it is very frustrating. I have tried turning it off and on and taking the battery off but there is still no response.
Hi, why the touch screen of the phone is not responding is because the touch screen of the phone is damaged, might be caused by hitting the phone on the flow or hitting the phone somewhere.
You will need to replace the touch screen for it to respond to touch.
Take care.
Sep 14, 2010 | LG Dare VX9700 Cell Phone
I have a lg dare and the touch screen is not responding
Try calibrating your touch settings.
  1. Go to settings
Aug 19, 2010 | LG Dare VX9700 Cell Phone
The touch screen on my LG Dare keeps vibrating and activates different commands, calls, etc and sometimes it won't respond to actual touches
Hi, when a phones touch screen malfunctions, it means that the touch pad is damaged seriously and it needs to be replaced.
Mostly it is caused by dropping the phone on the flow, hitting it on something or even pressing the touch screen pad with the wrong instrument.(any sharp object).
You can take it to a here by store for a replacement.
NOTE: phone is very delicate needs to be handled by an experienced personnel.
Take care.
May 19, 2010 | LG Dare VX9700 Cell Phone
LG dare cracked LCD but touch works
Send the phone into LG, they will have there technician diagnose the phone. I have the exact same problem. I took my phone out of my pocket and there was a big crack on the LCD screen. My phone is going to LG Canada today, they (LG) told me it sounds like a manufactures defect.
Hope this helps.
Aug 25, 2009 | LG Dare VX9700 Cell Phone
Unresponsive touch Lg Dare Touch screen
sometimes you just need to take the battery out and put it back in. If you've already done that then you may need to take it to Verizon and get it updated.
Jul 09, 2009 | LG Dare VX9700 Cell Phone
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
LG Dare - screen is black with long colored skinny line!
take the battery out for a minute, then replace. ushould be okay! good luck champ!
Apr 25, 2009 | LG Dare VX9700 Cell Phone
LOCKED PHONE
my touch screen wont respond lg dare vx9700
Mar 28, 2009 | LG Dare VX9700 Cell Phone
You can buy a new water proof touch screen online and you will be able to go to a Verison store and have them install it for you. Also put the phone in a zip-lock bag full of uncooked rice for several weeks. Make sure the battery and phone are in the bag seperately.
Jan 02, 2009 | LG Dare VX9700 Cell Phone
Lands Phones Logo
12,300 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
