My machine will not read previous dvd's recorded on it
    Genius:
  • 1,139 Answers
Hello john750,
You can try a cleaning disk, however it has been my experience that the cleaning disk will not help, but it is a good place to start from. More then likely it is a problem with the laser pickup photo-transistor, these often malfunction causing this problem. I would suggest if you are going to try to repair this yourself, you will need a multimeter, a laser meter, and a schematic. The first step is to measure the laser energy leaving the laser diode and see if it matches the specifications in the schematic, if it does not, check the bias voltage with the multimeter, this is to determine if the problem is the bias voltage or the diode itself. If the diode is bad replace it. if the diode is good then the pickup becomes suspect. Using the multimeter measure the bias voltage on the photo-transistor with and without the presence of the laser light from the diode. This will tell you if the photo-transistor is good or bad, if the transistor is bad replace it , if it is good check the components that make up the biasing circuitry.
Now This test will produce a test of go or no-go on the laser diode and the photo-transistor. One of these components or their related biasing circuitry is either bad or about to go bad, by testing the voltages and laser light levels you should be able to determine which one or if both have a problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 08, 2008
Hello, My Philips DVDR7300H has a recording error after burning to dvd - burns VERY Slowly, and then gets hung on 95% - then "Disk Error" and the disk is then unreadable. It reads other previously recorded...
This happens with a number of drives.
1. DVD Dye type - but as you have tried DVDs from a batch that works seems unlikely.
2. Some drives dont like +R or -R If using +R try -R etc. Also some drives have problems with RW's used previously
3. Drive head travel is faulty. Sometimes only recording a max of 4Gb or 90% on a disk works OK.
Good Luck
Jun 10, 2014 | Philips DVDR7310H DVD Recorder / HDD...
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
My tv/dvd combo is emerson ewc13d4 but it does not read any discs it reads play back feature is not vailable.
Despite the mention of playback, do you mean this is when you put in a blank DVD to record?
Are you just getting started with it?
There are two sub-format of discs that can be used for recordings.
Machines will support either DVD-R or DVD+R but recently some now take either.
Check in the instruction manual which type yours uses (because if it supported both we'd have no problem)
However, if this is about playback of your own previously recorded or commercially released discs (movies) then check a disc is clean and free from marks, blemishes and especially scratches.
(Great things, optical discs but very touchy about the state of the surface because of the laser reading method)
Next up is to clean the scanning lens in the machine.
This is done easily with a Lens Cleaner disc kit available everywhere very cheap.
Follow the instructions that will come with it.
If no joy after this it's back to the shop - if guarantee still applies - or to a repairer if not. Get a quote and see how you feel about that or getting another recorder.
Sep 24, 2011 | Emerson EWR20V4 DVD Recorder/VCR
When attempting to record on a DVD-RAM disc the unit says that the disc is read only. This disc has been recorded on previously. Tried a new DVD-RAM disc with the same result
have you tried recording on a standare DVD disk, either DVD+R or RW or DVD-R/RW? if those don't work either, you have a bad recorder.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
LG RH177 - Cannot read discs....
Well, to solve the problem quick, I actually called in the service guy. Over here, LG comes to the door, but at an extra $40 bucks excluding parts. What I realise is that the drive is very easy to install, so could have just bought the part and installed myself, saving the $40.
With a DVD drive, it is hard to pinpoint the problem. And it being so cheap (old tech/over supply), most service centres would just replace the whole thing.
Aug 12, 2008 | LG RH177 DVD Recorder/HDD Recorder
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Mar 30, 2008 | Panasonic Diga DMR-EH75V DVD...
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Disk reading
2 questions her 2 problems 2 answers. 1.Recording The machine is probably fussy about the type and brand of blank disk it will work with. Check your manual and sample several brands 2. Playing the burned disk you wish play if from another device has to be finalized in the burner machine.
Jul 30, 2007 | Sony RDR-GX315 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
