I got Sony XMZR604 4 Channel Amplifier in my car and it is not working any more. The red power protector indicator is on. I have checked all the connections but it is still not working. Can u plz give me some assistance in wat I should do ?
This usually means that the speaker outputs are being shorted out or ground is not secure. My suggestion is to turn it off and recheck your ground and speaker wires to check the are secure.
Posted on Nov 17, 2008
I HAVE SONY DAV-DZ270 HOME THEATRE. IT IS DISPLAYING PROTECTOR PRESS POWER. HOW TO SOLVE IT?
Usually this is caused by a faulty power amplifier. Fault find and repair the faulty channel.
Dec 09, 2017 | Sony Audio Players & Recorders
Amp light not working and one dead right channel
Without knowing how it's actually laid out, I'd surmise the output amplifier transistors in the right channel are shorted, the fuse for that channel may be blown, and the speaker protection circuit is keeping it turned off. Most amplifier speaker protectors disable both channels if there is a problem, but yours could be different. I surmise the lights you mention are directly connected to the speaker protector chips and indicate readiness for normal operation. If it takes a few seconds for them to come on after power-up, that lends credence to my hypothesis.
Unplug the amplifier, open it up, and measure the resistance from the right channel output to each of the output power supplies (or to the fuse for the output power supply for that channel, if present). If one or both is very low (i. e, close to zero), you have a fried transistor. If that is the case, it is probably a good idea to replace the complementary transistor connecting the speaker to the other power supply even if it tests good; it may have been overloaded when the first one shorted. In many amplifiers, the transistors are inside a hybrid amplifier module, so you would have to replace the entire module. In some amps, you have multiple transistors in parallel; here you can probably keep the transistors that were in parallel with the failed unit, but I'd still recommend changing the complementary transistors.
Apr 23, 2014 | Volfenhag ZX-5168 2-Channel 4000W...
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
Power protector light on but no sound
this meens that the unit is protecting your speakers from damage, unit need repair,probibly a blown channel
Apr 27, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Amp repair
Check all your connections to make sure wiring is correct, if the light stays red you have an internal fault in the amp.
Jan 27, 2010 | Sony XM-SD46X Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
1000w Sony Xplode car amp
Sounds like the power supply is shutting down because of it sensing a bad output channel. I'm assuming of course that you have checked all your battery, ground, and trigger wires to see if they are OK. Good luck.
Apr 05, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Nov 04, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
204 people viewed this question
 Grubhead
Grubhead
