Question about Compaq Computers & Internet
I need to buy a power adapter for Compaq C504EA notebook.It is only 18 months old and this is the 3rd time the charger needs replacing
    Problem Solver:
  • 5 Answers
Hi
Your best bet would be to have a look on ebay for the charger. i've posted a link. just look around a bit you will find a lot more.
As for the ac adapter frying.. looks like you have some voltage issues. use the adapter with a powerguard or power stabilizer.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=250282392936&Category=31511
hope this helps
cheers
kbh
Posted on Oct 09, 2008
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
No power at all
You need to get a new laptop charger. Just buy one from amazon,ebay,bestbuy or a prefessional online store, such as chargerbuy.com.
Compaq Presario AC Adapter
Oct 30, 2012 | Compaq Presario 2170US Notebook
I misplaced my power cord to my notebook. How do I determine which powercord is the ccorrect one?
A) Look on the bottom of the notebook. Usually states the Voltage (V) and Amperage (A)
Should state > Input: 18.5V/3.5A
(18.5 Volts at 3.5 Amp's)
B) Look at the charger;
The AC adapter (Charger) will state;
Input: 100 ~ 240V/50 ~ 60Hz
Output: 18.5V - 3.5A
Should look similar to this,
http://www.buy.com/prod/65w-new-ac-power-adapter-charger-cord-for-hp-compaq-presario-c300-c500/q/sellerid/24353325/loc/101/213887466.html
Nov 29, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
Compaq Presario CQ60-215DX. Doesn't start
You will need to buy a new battery, there is no way old one will be OK. To see if it works, remove battery, and use wall adapter ONLY, PC should work fine. If not maybe Flat CMOS, replace, If replace and still NO go.must be bad motherboard (maybe try charge battery 5 hours left alone)
Mar 27, 2010 | Compaq CQ60-215DX Notebook
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just...
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Sep 27, 2009 | HP Compaq Presario C500t Notebook
No Power vailable to Compaq R4000 PN495AV
well..this will require a new motherboard(around 200.00) and two hours of tech time(around 200.00) so compaq was high, but not that high..
check in the repair listings at fixya for more on this option
May 23, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
