Question about Coby MP-C951 Digital Media Player
Coby MPC951 Hi I recently changed the hard disk of Coby MPC951 since the old disk had some problems. But the new disk is just formatted and does not contain the firmware files in it. I have connected the new disk to the player but I still get the message "HDD read error" and if I connect it to the PC vis USB, the player itself is not getting recognized. How to I install the firmware in it now? I'm able to connect the hard disk to the computer separately using a ZIF connector and read the drive. My email is krishmukesh@gmail.com
3 Suggested Answers
SOURCE: mpc951- coby
my mp3 wont turn on any more it use to say read HDD error every time i turn it on and it would just go to the radio.
Posted on Oct 29, 2008
  • 2973 Answers
SOURCE: In my Coby MPC951 I
The LCD seems to have got disconnected from the mainboard. Please open it up and re connect the ribbon cable to the LCD. It happens to be press fitted. To give this connection more stability, reinforce it with cello tape. If you feel faint then seek some professional help. It is a matter of five minutes.
Posted on Oct 22, 2010
Tip
Think Twice Before You Put Your Old Hard Drives On Sale
A new study reveals that used Hard Disk Drives available on classifieds websites contain high-risk data
A recent analysis done by Stellar Data Recovery, one of the world's leading data recovery, data erasure and data migration solutions provider reveals that hard disk drives available on second-hand marketplace sites contain a huge amount of confidential data. As part of the study, multiple hard disks drives were purchased from India's leading online platform which facilitates buying and selling of second-hand products. For the sample collected, sensitive and high-risk data was uncovered in 100% of cases.
Most consumers in India are unaware that data can be recovered from their legacy drives and mobiles and steps like formatting are not enough for ensuring data privacy. The study further reveals that the vast majority of Indians are still unfamiliar with data sanitization methods; often referred to as data erasure methods, data wipe methods, wipe algorithms, and data wipe standards. This eye-opening study now mandates the need of consumer awareness for both individuals and business alike, about their own Data Privacy and the need to adopt proper and secure data erasure techniques before discarding legacy gadgets; this is a pre-requisite to keep cyber criminals at bay.
Sources:
Stellar Data Recovery Study Think Twice Before You Put Your Old Hard...
Disposing old Gadgets Safeguard Your Personal Data First
on Dec 27, 2017 | Computers & Internet
Hi I'm having a problem with my HP Mini The problem is that when I turn it on it won't get pass the Windows XPs loading screen while its loading on the Windows XPs loading screen the screen turns...
HI FRIEND YOUR PROBLEM IS THAT YOU NEED TO FORMAT YOUR NETBOOK AND SET UP THE WINDOWS FROM THE BEGINNING. MOREOVER, YOUR HARD DISK MIGHT HAVE A PROBLEM AND YOU MIGHT NEED TO REPLACE IT AND THEN YOU SHOULD FORMAT YOU NOTEBOOK . I BELIEVE THIS SHOULD WORK
Apr 09, 2011 | HP Mini 1000 Netbook
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
Can't get movies to play
Hello!
The error "Frame size too big." means that the video's Frame Rate is higher than the supported frame rate of your COBY MPC951. To fix this, you need to convert the video to run lower frame rate. You can use any video converter in the internet.
Cheers!
Ryan
Jun 11, 2009 | Coby MP-C951 Digital Media Player
To backup my data
you can use you 160gb HDD as slave in your old pc. then coppy your files and save it in the old pc HDD. affet you back up your files you can put back your 160gb HDD in your original pc and you can format it now. hope you can use this one.
May 31, 2009 | Gateway 310S (2900621) PC Desktop
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Downloaded videos on Coby wont show up
The file corrupted or contains an invalid codec. http://www.cobyparts.com/
May 01, 2009 | Coby MP-610 MP3 Player
Mpc951- coby
Jun 08, 2008 | Coby MP-C951 Digital Media Player
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Coby MP-C951 Digital Media Player Logo
44 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
