Mag Innovision 700P LCD Monitor
Can I know How to open this monitor to fix the power supply failure of thie monitor? I hope it's SMPS power supply is broken. I found two screws back bottoms. but i couldnot open it.
I hope sombody will help me to know that.
Thank you.
gmekochi@yahoo.co.in
  • gmekochi Oct 10, 2008
    Thanks for your advice. I hope i could find out the failed compnent or can add other power if its is opend. but i never opened any LCD monitor. My quiry is to open the monitor without any damage of the body and locks.
  • 5,568 Answers
You didn't mention any symptoms but if it just refuses to turn on you are probably right.
One word of caution; finding a bad IC, a failed transistor or diode may only be a sign of the illness. Check every electrolytic capacitor in the supply; there are thousands of failures of some values and if you find some failed, hope for & check the date codes on the replacments and try to avoid the period of 2003 to 2006. There are millions of capacitors from many different companies that have defective electrolyte in them.
Posted on Oct 10, 2008
  • Steve Allison
    Steve Allison Oct 10, 2008
    It isn't uncommon to use molded tabs that would normally be found 180 degrees away from a few screws; i.e. if the screws you have found are located low on the back, carefully pry along that edge to see if it will come out; if it does, then the other edge may slide out when the first edge is pulled out somewhat.
    Also, for cosmetic reasons (appearance) some screws may be under plugs that are fitted into the holes to conceal the screws.
    If that is the case, the plugs may be damaged when removing them.
I have a mag innovation flat screen computer monitor but I need the power cord for the monitor it is a LT717S model # 700P made in 2006
The power lead you need for this monitor is a standard EU 3 pin. you can purchase these from any good electrical or computer store.
The look like the old Kettle plugs if its of any help
Jul 24, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
Feb 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
813 people viewed this question
David Payne
David Payne
