Question about Brother FAX-T74 Plain Paper Thermal transfer
2nd hand fax machine showing fax no of original owner
We have been given a fax by a member of staff & plugged this into our fax line. Having used the fax today, the receiver of the fax has noted that the number displayed (which should be our number) is the number of the original staff member. How do we change this? Thanks.
    Genius:
  • 2,120 Answers
Scroll through the menus to "Register own ID"
Posted on Oct 09, 2008
I have a second hand rear facing maxi cosi car seat and need to find out how to install this properly? Please send me instructions or installation guide etc.....
Hi Vanessa - We cannot recommend you use a 2nd hand carseat for exactly this reason. A carseat fitted with a 3 point seatbelt requires a physical fitting from a trained member of staff prior to purchase to ensure suitability, and to demonstrate to you how to correctly install it in your car to ensure your child is safe. Please attend an authorised retailer and ask for a carseat fitting from a trained member of staff to establish the most suitable carseat for you and your vehicle and to ensure you know how to fit it correctly.
Apr 18, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
We are having problems receiving faxes but printing is fine we do not seem to have a ringtone signal
First make sure dial tone form wall is working, just plug in a hand set. If no dial tone, call phone company. If dial tone then make sure line is plugged from wall into fax port that says Line not TEL. Can you send faxes ok?
Apr 04, 2011 | Brother Office Equipment & Supplies
Need to set up machine was given as gift
There are two ways to use a fax machine in your home or office. You can either have a standalone fax machine, or you can use your computer for this purpose. Either way, setup is very simple. You don't even have to be a tech guru to do it. First, decide if you'd like to have a separate phone line for your faxes so they don't interrupt communications at the office. If so, have the phone company install the line before you get started with fax setup.
Setting Up a Traditional Machine
  • Step 1.Set your fax machine on a flat and even surface. Plug the power cord into the wall. Fill the paper tray and slide it into the front of the machine.
  • Step 2.Plug one end of a standard phone cable into the phone jack and the opposite end into the port on the fax machine. It's usually on the back or the side.
  • Step 3.Turn on the machine and pick up its telephonemag-glass_10x10.gif. If you don't hear a dial tone, check your phone cable to make sure it's secure. Then turn to the LCD screen and start programming your options. Since all machines are different, see the instructions in the owner's manual.
  • Aug 03, 2010 | Office Equipment & Supplies
    Do not have a owners manual to show you how to fax. A sharp ux-114 fax machine.
    ....and you won't likely find a manual for that old one.
    What's so difficult though?
    Plug in the power, plug in the phone line to the "line" jack, put in your page(s) face down, dial number , hit "start"
    Mar 30, 2009 | Sharp Office Equipment & Supplies
    Difficulty sending a fax
    Hello. Please make sure your telephone line is plugged into the correct outlet.
    Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
    In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
    http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
    This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
    http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
    This will show you how to actually send the fax. On your PDF View select page 42.
    Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    How to connect canon L295
    Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
    May 02, 2008 | Canon L295 Plain Paper Laser Fax
    Unable to get my Intellifax 775 to receive any fax's
    Things to check: Do you have a live phone line? Are you using a dedicated fax line? You can check your fax line by using the feature hook call. Not all machine have them. Or use the hand set. If you have a live phone line now check this. Is you fax set to auto answer? If it is not you need to either find how to set it on the diplay or refer to your owners manual. If this does not work after you have done this then you possibly have a bad modem.
    Mar 17, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
    Fax line stays busy continously...
    Still a problem? Can you be more specific?
    Jan 29, 2007 | Canon FAXPHONE L80 Laser
    Brother FAX-T74 Plain Paper Thermal transfer Logo
    74 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
