Question about Onkyo TX-DS575 Receiver
Onkyo TX-DS575X, remote intermittend malfunction
On my TX-DS575X is the following problem:
Most of the times the remote is not working (Yes, I pressed audio button first). Sometimes when it works, I can switch the instrument on and after approx 5 minutes it does not respond anymore to the remote. Everything else works fine.
I opened the reciever and cleaned the IR eye, no solution.
I bought another TX-DS575 (without the X) and my own/first remote works fine on this one(so the remote is not the problem) Also the remote of the DS575 is not working on the DS575X
  • Anonymous Oct 18, 2008
    I have the same problems, I send my TX-DS575 to repair, the engineer said that it is because the receiver has malfuction, they replace another spare part and everything alright.
  • Anonymous Jan 08, 2009
    I have the same problem. Where can I send my TX-DS575 for repair?
    Welcome Back:
    Visited the website for 2 consecutive days.
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
Posted on Jun 12, 2009
I replaced the IR unit on the receiver with p/n RPM-H4R-ND from Digi-Key $1.40 . remote now works fine. I don't know for sure but suspect that leaving the unit in the "stand-by" mode for long (weeks) periods caused early part failure.
Posted on May 24, 2012
  • Harv Nov 13, 2012
    Is it difficult to replace the IR unit? You remove the screws on the front cover, remove the front cover and the simply remove and replace the part or is it more complicated than this (any soldering required)?
    New Friend:
I did the same : I replaced the IR unit on the receiver with p/n RPM-H4R-ND from Digi-Key... works fine now. Thanks alot for your tip.
Posted on Jan 10, 2015
  • Luc Morin
    Luc Morin Jan 10, 2015
    My amplifier is the TX-DS595 but the solution is the same ;-)
SOURCE:
My onkyo tx-ds575x lost power in a storm and now I get no audio from it. The sony bravia tv has sound but the onkyo won't send it to the speakers.
Please reset Onkyo receiver that will solve noisy sound problem, to reset the receiver, press and hold Video-1 button on unit and press Speaker-A button. Display will show *Clear* that means receiver has been restore on default settings, turn it On and check sound.
Hope this will help.
Thanks.
Apr 06, 2011 | Onkyo Audio Players & Recorders
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Nov 17, 2007 | Onkyo TX-DS575 Receiver
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
Onkyo tx sr502, sounds coming from all speakers except sub. in test sub works
hi,
Try the following setup to activate the sub
1.Press the [AMP] button on the remote and then press [SETUP] button.
2. Use the Up and Down arrow buttons to select "1. SP Config," and then press the [ENTER] button.
3. use up and down arrow to select subwoofer setting.
3. While the subwoofer setting is selected, use the Left and Right arrow buttons to select Yes .
you will surly get the audio from the subwoofer.
ok
Feb 19, 2011 | Onkyo TX-SR503 Receiver
Onkyo tx-sr804 ..problem with the remote
PRESS THE RECIVER BUTTON THIS SHOULD WORK THE AMP AGAIN.
HOPE THIS HELPS.
CABLE GUY.
Mar 26, 2008 | Onkyo TX-SR803 Receiver
ONKYO TX-DS575X - Speaker B not working
You may have blown one of the speakers. Put a different set on them to test this theory.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
2,348 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
