I would like to reset my wireless router becaouse i forget my password and i dont now what i must to do now??
  • 33 Answers
most of the routers have a reset button on its rear side or under it. try to find the reset button and press it continuosly for 5 sec until it resets. default ID would be ' admin '  Password would be  ' password ' .  these login details may be found under the router. if still couldnt do it let me know the model of the router so that i can assist u with the exact procedure.
cheers
Posted on Oct 08, 2008
I dont no my password are username
Normally the default user name for router is "admin" and "password".But again you must refer to your wireless router support manual. It can vary depending on your router brand.
If you forget password then you need to reset router using reset button.After reset ,the router restore the default settings.
Aug 20, 2012 | NetGear WGT624 Wireless Router
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Jun 24, 2012 | D-Link Computers & Internet
Need to find out password or how to reset a new password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
Lost security code for wireless linksys router
Hi alockklock2,
If you want to obtain the password or security on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Linksys Wireless-G WRT54G Router
Cannot get router to reset. Have tried holding in reset button for 30 seconds, then going to 192.168.1.1 and leaving user blank and passwrod admin. still wants a user id and password, so only conclusion...
try ADMIN for both username and password
if that does not work unplug the power cord and hold the reset button while plugging it back in
hope this helps dont forget to rate
Jan 07, 2011 | Linksys WRT160N Wireless Router
Forget password
if you forget your router password or your wep password, the easiest way to fix this is reset your router.
on the bottom of your buffalo router there is likely a recessed button that will reset the unit to 'out of the box' default settings. you will have to enter all your information /time/date/wireless security settings from scratch.
Dec 16, 2010 | Buffalo Technology AirStation Nfiniti...
Lost my linksys wrt160n password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then click on WEP and there is code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Sep 01, 2010 | Linksys WRT160N Wireless Router
Dont remember my password
How about resetting the router and creating a new password, one you're less likely to forget?
May 08, 2010 | D-Link DI 514 Wireless Router (DI-514)
Forget wireless-G broadband router, how do I change it
There is a reset button in the back, small pin hole, hold it in for 10 seconds.
This will restore it to when it was new so you will have to reset all your settings.
The user will be- admin and the password -linksys
or check your manual if these don't work.
Feb 11, 2010 | Linksys Wireless-G Broadband Router
I dont know the password for this router
Generally, when you forget a router password, you have to factory reset it and then use the factory password to access it. Do you have the manual? It should tell you how to reset it and what the default password is.
Jan 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
David Payne
David Payne
