Question about Minolta EP1083 CS/PRO Copier
Minolta 1083 Scanner lamp is not working and showing the code c04
  • sam gerban
    sam gerban May 11, 2010
    IS THIS A **** SHEL MACHINE?
  • 145 Answers
Sound like fuser prob
if this a **** shell machine .there is a reset botton on CB in the back of the machine .
hope that help
Posted on Oct 12, 2008
I have a minolta Photocopier CSPro EP1080 that keeps displaying an error message; C04 with a Spanner sign as well, what will I do?
Exposure lamp is burned out or the board the operates it is or both. The exposure lamp is the very bright light hat comes on when you make a copy under the the big sheet of glass. Raise the document feeder up and press start button does the bright lite come on and scanner move?
Try to reset. power off the machine, remove the top rear cover. Find the main circuit board now turn on the machine wait for code to show up and press the small black button on board lower right. if the code comes back try below parts.
Try this site for the lamp as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 10, 2015 | Minolta Office Equipment & Supplies
Whats the problem if code C04 come from Minolta EP1083
The error code is displayed in 2 section on the display on the zoom dosplay and the number display.
C0400 Exposure lamp malfunction.
C0410 Exposure lamp thermistor malfunction.
Verify the exposure lamp continuity and the thermistor continuity.To reset error code open the copier and press the reset microswitch located on the rear PWB panel ,close the machine front door.
Jun 02, 2013 | Office Equipment & Supplies
My konica minolta ep1050 is displaying error code c04 can you help me how to fix it
this is not the correct error code konicsa has 4 digits is it a c0400 if so it ids the home poition sensor for the scanner clean the sensor blow it out and see if that gets rid of your error code
Jan 31, 2011 | Konica Minolta Office Equipment & Supplies
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Minolta CSPRO 1083 - Turns off / wrench icon
Exposure lamp problem.The exposure lamp turning ON at abnormal timing.Please check the exposure lamp continuity,the expo lamp thermal fuse,master board(PWB A) AE sensor board(PWB H and the expo lamp regulator PU1.
For reset open and close the front door.The trouble reset switch must be presed afternthe power is switched on to reset the malfunction of the fusing and exposure lamp sections.
Sep 21, 2009 | Minolta EP1083 CS/PRO Copier
C04 in Ep1080
The exposure lamp is it coming on? Thats the real bright lamp under the glass where you put the orginal documents, To reset open close the front door., Code C-0410 is the lamp is on to long. Check the scanner itself that it moves any loose connections or binding?, Mite have a problem with the scanner circuit board? Second reset is behind machine, remove back cover, looking at the circuit board from the rear your left side see a small black button on the board press it. copier must be on
Aug 08, 2009 | Minolta Office Equipment & Supplies
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
Showing c04 problem
no cods?
can you take lamp out ? check with aom meter .sould have coninuity
hope that help
Oct 08, 2008 | Minolta EP1083 CS/PRO Copier
Meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
131 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
