Question about Minolta Office Equipment & Supplies
Minolta QMS magicolour 330-2 printer CYAN TONER MISSING
    Problem Solver:
  • 6 Answers
You need to empty the "waste" toner from the cyan toner. If you're not sure where to find it it is the smaller of the two holes found under the retractable flaps at the top end of the toner container. A tricky job for an end user as they are designed not to be emptied (there is a one way valve).
The best way to cure this problem is to replace the toner with a new one (not a refurb) or send the toner back to where you got it.
Posted on Mar 13, 2009
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
Magicolor 330 ex firmware
Legacy machine from Minolta they branch QMS, no longer in service, Minolta now Konica Minolta, tray below Self Help Product Support Konica Minolta Business Solutions Inc
Oct 13, 2012 | Minolta magicolor 330 EX Laser Printer
How do I change the ink cartridge?
Hello.
This printer is a laser jet printer - so you will be changing the multiple toner cartridges, not ink cartridges.
Page 56 starts the steps on how to replace the toner cartridges.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2300dl/eg_user.pdf
The front of the printer opens to the right and exposes the toner cartridges for removal.
May 04, 2010 | Konica Minolta magicolor 2300DL Laser...
From cold the fist page to print jams error on printer Media Jam Registration If you print a job then, run another whilst it is still warm it's fine. Just printing from cold it 90% of the time jams (Media...
Print jam problem -see here for solution, worked wonderfully!
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/186ca4b0866ef839c1256f910078f284/$FILE/MC3300-Paperjam%20registration.pdf
Jun 15, 2009 | Minolta magicolor 3300 Laser Printer
Need Override for Low Toner Message Minolta QMS 2300
It depends on the model. The 2300 series using a mechanical mirror on the cartridge itself. A tab needs to be moved the mirror slid back to home. The 2400 series & newer uses an IC that you need to replace. when you buy your toner to refill the cartridge make sure you get the IC with it. Russell
Aug 21, 2008 | Minolta magicolor 2350 Laser Printer
138 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
