Question about Lightning Audio B2.300.2 Car Audio Amplifier
Amp won't turn on
My amp, when hooked up, will not turn on. the green power light does not come on, instead the red 'protect' light comes on solid when i power the amp by turning the head unit is on. I have checked and double checked the wiring and it is all sweet, so I have no idea what is wrong with it. Help!!
  • 905 Answers
Disconnect audio inputs and outputs and see if one of those are causing it , if it still does it with all audio inputs and outputs disconnected then there is a problem with the power amp
Posted on Oct 08, 2008
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
Green light (protection mode) on, NO red light (ready)
double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
Sep 05, 2009 | Kenwood Car Audio & Video
Hi there just picked up a jbl bp 1200 for good price although just wired it up and turned the key to find the red light come on few seconds then solid green and no sound...checked ground,remote wire rca...
Most amps do a "power up" where all the lights can come on, then settle into "green light" or some sort of "ready status" light comes on. The red or yellow lights can indicate "protection mode" (a bad amp) and green is the universal signal for okay. - So try this - Double check your connections and the amp. Pay close attention to the settings on the amp before you declare it not working. I have had many amps (especially newer ones) cause problems from a simple switch that was in the wrong position. Be sure to use good power and audio cables matched to your amps capabilities with good strong grounds on a clean non-painted metal surface. If all is in order from there start checking your signal from the deck to the amp. You can also check manufactures website for the manual, (if you didn't get one) looking at it may give a clue about proper switch configurations and hook-ups. Let me know if you need additional info concerning these idea's.
-Dynami
Apr 15, 2009 | JBL BP1200.1 Car Audio Amplifier
Red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Mar 24, 2009 | Polk Audio PA250.2 Car Audio Amplifier
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
The red light on my amp keeps coming on and it wont work
You need to check your woofers. Most likely one or both may be a) blown or at a dead short or b) the ohm rating on them may be too low. What model woofers and amp do you have??
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
Lightning Audio B2.300.2 Car Audio Amplifier Logo
378 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
