Question about LG Washing Machines
Wft-852a washing machine not filing up with water
    Genius:
  • 1,122 Answers
Have you checked the inlet water valve on the back of the washer?try setting it water temp on all the setting and see if anything happens,try unplugging it to and see if it resers its self,let me know-mike
Posted on Oct 08, 2008
Washing machine not washinf/spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Bosch Logixx WFT 2806 Front Load...
I got washing machine model WFT 65A31EC with "dE" appears while we are washing. Pls advise what to do next.
YOU WILL NEED TO TAKE OFF THE FRONT PANEL. CHECK THE THERMISTOR CONNECTOR. SOMETIMES IT GETS LOOSE. MAKE SURE YOU HAVE GOOD CONNECTION. YOU CAN TAKE THE THERMISTOR OUT. CONNECT OHM METER TO IT. RUN HOT WATER ON THERMISTOR, OHM READING SHOULD CHANGE, THEN COLD WATER, IT SHOULD CHANGE AGAIN.
Jan 16, 2010 | LG Washing Machines
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing machine wont rinse or spin keeps saying f18
I just fixed my machine through this site, it means the drainage hose is blocked.
The small access door at the front has a hose and a small screw cap. I drained the water via the hose then undone the screw cap and found it was blocked by tissue.
Put everything back and now is working.
Jul 09, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Instructions for a washing machine bosh wft 6030
Which machine and model do you have ?
Sep 06, 2007 | Washing Machines
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
WFT 2800INSTRUCTIONS
http://www.bshappliancecare.com/Bosch/ click "instruction manual download" type WFT in the search box, and you are taken to the downloads page - sorry i couldn't link to it directly. Hope this helps :)
Feb 09, 2007 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
66 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
