Question about LG Washing Machines
Have wft802 lg washing machine works until spin cycle wont spin or drain water have taken outlet tube off back of machine and water was pouring out.put tube back on but still spin cycle wont do anything
    Genius:
  • 1,122 Answers
Sometime the lip switch sticks or goes bad,have you checked that?let me know-mike
Posted on Oct 08, 2008
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Jun 17, 2009 | LG WM-2277HW Front Load Washer
THE WASH REACCHES DRAIN AND SPIN STOPS THEN ENDS CYCLE
pump is blocked check your filter at the front some have a small drainage tube there to remove the water. failing that tilt back machine slighty open door and remove with a jug, remove filter uscrew and pull and check for foriegn objects i.e coins screws,whilst tilted back squeeze the two rubber tubes to the pump to make sure they are clear or unclip if need be MAKE SURE POWERS OFF lay some towels down sit machine back down slowly there will be excess water and with filter out run machine SPIN ONLY if it does you've solved your problem also check your waste and outlet pipe your waste could be pushed too far down the outlet pipe 6" is adequate enough.good luck
May 18, 2009 | Zanussi FJS1225W Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
WM1832CW, wont drain and spin, has LE error, was able to drain water, using spin only function, still would not spin, sounds abnormally, drum is not moving at all. I know LE means motor overload, but what...
Dec 12, 2008 | LG WM-2077C Front Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Jun 09, 2008 | LG WFT1071TP Top Load Washer
Daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Dec 02, 2007 | Washing Machines
LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Aug 30, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
249 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
