My wash mashine is wont start. but its not because of the door hasn't cloth properly, power or water pipe line. it seems every thing is alright but it won't move.
  • 24 Answers
Mor information please.What sort of machine model etc. Does it fill with water .What doesn't it do. Your question is too general.
Posted on Oct 08, 2008
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Oct 02, 2012 | Whirlpool Washing Machines
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
White streaks left on clothes
1.Have you used too much detergent and it hasn't all rinsed out...was the machine overloaded and the rinse cycle can't penetrate the MASS of wet fabric.
2. If you are in a hard water area, could there be limescale build-up/ mineral deposits within your inlet pipes/hoses.
3. Did you use a biological powder instead of a colour or non-bio detergent and these marks are now actually 'bleached' dye lines.
Jan 27, 2012 | Electrolux EW1200i Front Load Washer /...
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
Whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Zanussi washing mashine zwf 1220 w water overflou
Why not just reduce the pressure at the inlet wall faucet. But dont reduce it too much or your clothes wont rinse well.............
Jan 04, 2008 | Washing Machines
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
