HP DV9200 series AMD Cant recognize new samsung 500 Gb hard drive, is there a boot able patch to run for BIOS currently have F.40 Bios.
  • Computers & ... Master
  • 787 Answers
F.40 is the latest bios for this system (it just came out Aug 2008).
If you have one of the model that supports 2 drives and the problem is that it does not show up in windows, you probably don't have a bios problem.
Right click on My Computer - or just Computer if you have Vista
Select Manage
A Computer Mangerment windows will open.
Click on Disk Management
The attached drives will now appear on the right.
Do you see an unidentified drive, no drive letter etc?
Right click on it and initialize the drive, now create a partition and format the drive.
You can also assign it a drive letter.
Now you should be able to see the drive in My Computer (or Computer)
Posted on Oct 08, 2008
I have a compaq s5100nx desktop with a crashed 80 g ide hard drive.i am trying to replace it with a 500 g drive but the drive is not recognized by the bios i have tried 2 different drives already. However...
did you configured the Hard drive jumpers correctly?
Was the original HD set to master or Cable select?
if so please set your new hard drive to the same jumper settings as the old one.
Mar 19, 2011 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Hi!, I'm trying to install a brand new WD 500 Gb HD on a Dell Optiplex GX260. The problem is that even though I can see the HD on the BIOS Setup I can't get pass the Message... Press F1 for help or F2 (For...
boot to BIOS
turn on caps lock, scroll lock and number lock,
Press ALT+E (Should get a Single Beep) Press ALT+F (Another Beep) Press ALT+B (Reboot)
Make sure you have Windows CD in Optical drive and once it reboots it should start the OS load
If you don't have the most current BIOS, you may need to install old HDD, Download and install latest BIOS then repeat steps above.
Sep 02, 2010 | Western Digital 500GB My Book Pro-External...
How to solve boot failture.
Boot failure will be displayed if the computer cannot find the operating system on a bootable device.
Your hard drive could be defective or the computer bios is not setup to locate the drive due to lost information from a possible dead backup battery or a power surge. To resolve the problem you need to find out what type of hard drive you have for example MFM, RLL, SCSI, IDE, ATA, PATA, Enhanced IDE or SATA. With a SATA drive, you do not have to worry about jumper settings, which are the newest of the hard drive interfaces. You need to start your computer and read the system prompts to enter the set up bios (example: Press Del to enter System Bios). Once you are in the system bios you need to select boot devices. Make sure the drive with your operating system is selected in the boot devices. If this will not work then you may need to reinstall the Operating System. I would buy a new drive if you can afford it and install the operating on the new drive so you may be able to recover some of the data. If you do not care about the data you can reinstall the Operating System on the current drive. If your drive is not recognized during the installation then the drive is most likely bad. If you reinstall the Operating System on the new drive then you can install the current drive as a second drive to recover previous data. If you do not have a SATA drive you will need to change the jumper settings to operate as a slave drive. If the data from the old drive is not accessible when install with the correct jumper setting then the drive will need to be repaired or discarded.
Jul 20, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Installed 500 gig drive with Windows XP. Computer only recognizes it as 127 gig.
You need to go to your computer manufacturers support-driver site and look your model up, then put in your operating system and search for drivers. In the drivers column, you need to find the download for an updated BIOS. Download this file and run its self-executable program and flash your systems BIOS. The new BIOS will allow your system to see large hard drives...right now your system has a limit of 132 GB.
Jan 15, 2010 | Western Digital Caviar SE16 (WD5000AAKS)...
Getting a media test failure on initial boot up then windows blue screen pop up when windows tries to start. Is my video card not working properly? BIOS was reset.
probably hard drive failure.
try changing the boot order in bios.
if that doesnt work try reinstalling windows.
If windows doesn't reinstall then your hard drive is bad.
Oct 06, 2009 | Acer Aspire X1200 AMD Refurbished Desktop...
I have error wiht bios how can i resent bios for compal laptop khlb2
The bios is a piece of hardware. There is no data in your BIOS, it is all hard-wired. If your BIOS has an error, you would never be able to tell because the computer wouldn't be able to display the problem.
BIOS stands for Basic Input Output System, and that is what displays text on your computer.
If it is true that your BIOS is destroyed, there is no hope for the computer. It would be easier and less costly to buy a new one.
Jul 28, 2009 | Kanguru BioSTOR (BIO-HD35-U2-500)...
I have an HP Pavilion dv9000 purchased in 2007, 17" widescreen. Currently it has a 140GB harddrive that is almost full. I purchased a 500 GB harddrive to replace it but my computer won't acknowledge the...
It has to have SATA Hard Drive Connector DFHS22FR685, if you have this then I would try to format the hard drive to what your operating system is using, either NFTS or FAT32. The drive may not be properly formated for your system.
Jan 22, 2009 | HP Pavilion dv9000z Notebook
Booup of a custom system.
disconnect all hard drives except the one with your operating sytem and try that. You may have something hooked up wrong but you need to rule out other problems..can you see all the hard drives in the bios?
Jan 19, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
Bootcode - hanaro1
Most likely drive has firmware corruption. Here's some more info.
Aug 31, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
David Payne
David Payne
