Question about Philips 46PP9302 46" Rear Projection Television
Schematic for a 347h e10839 philips tv
I need the schematic for my tv the red convergence wont adjust
You have to replace the DSL Board to fix this problem
Posted on Oct 08, 2008
Why does my Philips 347H E10839 have no picture,chirps like a bird when I turn on?
thats an error code its beeping. sounds like capacitors on psu. google the beeps I.e 3 long one short
Sep 19, 2014 | Televison & Video
HELLO , I have sound but no pitcher MODEL #51PW9303/17F
If the picture was somewhat 3d looking before with colors out of line etc--what you have is a convergence problem that has got worse.
Seen a number of sets with this problem--on this model only way to know is locate the two chips, get at them and unsolder all pins on each--if set then comes on (will look bad) you know both chips need to be replaced.
If this is beyond you set is old enough to just replace it--average shop cost for this is over 200 parts and labor.
Let me know if you have questions.
Jun 11, 2012 | Philips Televison & Video
My parents think that there house got hit by lightning and now this TV (347H E10839) doesnt turn on, any sudjestions??
If you don't get a lioght on the front of the set at all then you need to remove the back and see if the fuse is blown, and if it is ok, then leave you set unplug for 40 min, and try again, the TV pocessor could be locked up do to the power surge and that will reeset it back to normal.
Nov 19, 2010 | Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
1/2 picture doubled while other half is normal. Philips E10839
Its a convergence problem which is common. Goto www.TvRepairKits.com and get a kit for your model
Jun 03, 2010 | Philips Televison & Video
Need the default coloring for the Philips 55P8341 tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Philips 55P8341 55" Rear Projection...
Red Convergence issue. Can't adjust. 3d picture.
If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. Please note that there are potentally dangerous hogh voltages present inside hte set even when unplugged.
Keep us posted on your progress.
Dan
Feb 21, 2009 | Philips 43PP9202 43" Rear Projection...
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips tv top corners and bottom going 3d
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Oct 24, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
742 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
