Question about Refrigerators
Fridge working intermittently.
I have a Bosch fridge freezer. The Freezer is fine but the fridge is not getting down to temperature and light is flashing most of the time when set on 4. Occasionally it does get down to temperature and the light goes out.
  • peterrichard Oct 09, 2008
    If it is the thermostat, how do I change it? Do I need to change the whole control panel? peterrichard
  • peterrichard Oct 11, 2008
    How do I change the thermostat on a Bosch Fridge/freezer Model KGS72320GB/01, or do I need to change the whole Control Panel?
    Brigadier General:
  • 6,966 Answers
Based on your post/description the freezer is working as expected. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • pls verify that the fan is turning drawing air from the freezer side to the fridge side;
  • additionally check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 11, 2008
    Genius:
  • 1,011 Answers
Sir/madam,
Order the thermostat.
Re-placing the thermostat.
TURN OFF THE POWER. Empty the fridge.
Remove the door using the star key on the two bolts at the top of the hinge. Do this with the door shut whilst the hinge is undone, then gently lift the door off over the light cover in the top of the fridge.
The thermoststat is behind the temperature control in the control panel at the top of the fridge. The coin operated 0 – 7 control on the right.
Remove the light cover by turning it leftwards and gently pulling it away.
Using a fine screwdriver or knife take the three covers out of the control panel. Behind are three bolts with the same size head as the door bolts. Remove them.
Remove the temperature control knob, or let it will come off as you take off the control panel cover. Gently ease the control panel off. It will probably be a bit caught on the thermostat probe tube.
In the back of the fridge is the cooling panel. Slacken off the two cross head screws which are clamping the thermostat probe to the back of the cooling plate.
Use the flat head screwdriver to push in the four spring loaded catches holding the cooling plate. Push in the sprung nob and whilst doing that pull the cooling plate of the mounting post (firmly but carefully). When you have undone the last one the plate can be swung aside to reveal the thermostat tube, unclip the tube from the back of the cooling plate and at the control panel withdraw the tube from where it goes into the top of the fridge. As you pull it out it will get stuck on any bends in the pipe behind the cooling plate so straighten it as you go. You can now cut off the tube if it is getting in the way.
http://home.howstuffworks.com/how-to-repair-a-refrigerator2.htm
thanks
good luck
    Genius:
  • 1,665 Answers
The thermostat cycles the refrigerator on and off.
The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature.
If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective.
If so, you need to replace it, because it cannot be repaired.
If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
    Genius:
  • 1,226 Answers
If the fridge is set to on below 4. the fridge is working fine? if this is the case then the temperature/level selector got fault.
if you can dare to fix then go on but if hard for you then you have to call the repairman.
may this help,
melnavz
Posted on Oct 08, 2008
  • Emelio Navaja
    Emelio Navaja Oct 14, 2008
    there is no problem on the on the thermostat since it is working fine. its probably the selector control got fault.
    melnavz
    Master:
  • 763 Answers
Sir, it must have been freon problem about the temperature or some switches and about the light just replace with a new one. better to bring to the repair service to have replace the freon and the light bulb too. if your fridge is cover on warranty then send it to the place where you bought it for a free service. hope that helps.
CHARCOIS
    Sergeant:
    Champion:
  • 331 Answers
I guess there is some problem with the thermostat
get it changed.....
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Bosch classixx fridge freezer. Freezer working fine, fridge not reaching a decent cool temperature. slighlty cool only.
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Nov 04, 2008 | Bosch Refrigerators
Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
May 25, 2008 | Refrigerators
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
