Question about Motorola Mobility L6 Cellular Phone
DAMAGED L6 I was attracted by the "modding" of L6 when i saw it over the net. all i got after is a bricked L6. i flashed CODE GROUPS separately into my phone, it got bricked. can i possibly revive it?
    Problem Solver:
  • 8 Answers
Ya do a testpoint flash and ure done
Posted on Oct 16, 2008
My wii is hooked up properly, but when I turned the input to the right place the screen is just black. The Wii remotes will not connect at all even when charging and the wii console's light is green.
Have you checked to see if it might be your cables that are damaged? Did you mod your Wii? If you tried modding your Wii and now youre getting just a black screen it might have gotten bricked. Also try using it on a different TV.
Aug 05, 2011 | Nintendo Wii Console
Jeep charokee has no engine fire,check crank position sensor it was loose wires were fraid i replaced sensor still no fire
Firstly, you need to extract your vehicle's diagnostic codes - this will identify where the problem lies.
Instructions (using ignition key method):
Codes are shown by the Check Engine Light (CEL) on the dash. 1. Turn the ignition ON-OFF, ON-OFF, and finally ON again (without starting) 2. Codes will be emitted via CEL on the dashboard display. 3. Read codes as described below. Reading codes: Each code consists of two groups. The first group of flashes indicate the 'tens' digits. The second group of flashes indicate the 'ones' digits. A short pause separates 'tens' and 'ones' digits. A long pause separates each trouble code. e.g. Long flash, Long flash (short pause); short flash, short flash (long pause).....then repeats... The above flash sequence indicates Code 22. If you are able to get your codes, post them here and I can assist you further. Cheers, "If this has helped you in any way, please place a testimonial"
May 13, 2011 | 1993 Jeep Grand Cherokee
I want l6 reset code
hi,
Go To Settings -> Initial Setup -> Master Reset-> Code is 000000
esle try 1234
thank you for using fixya have a nice day:-)
Jul 24, 2010 | Motorola Mobility L6 Cellular Phone
Please I want to change the Language opreating system of my sony experia X1 from Spanish to English . Thanks
Hello.
You need to flash another ROM into your phone.
You can also install a modded ROM that will add more features to your phone.
If you're not confident flashing your phone (YOU CAN actually BRICK it), you're better taking it to a repair shop.
http://forum.xda-developers.com/showthread.php?t=397515 <-- A good modded flash.
Greetings.
Jul 31, 2009 | Sony Ericsson XPERIA X1 Smartphone
My abs light is on and my car shut off and wont come back on
Your ABS light is not directly related to your engine and would not cause your vehicle to shut down. Therefore, we need to have the Diagnostic Codes extracted from your vehicle's computer, before we can examine likely causes.
Assuming you cannot extract codes from the DTC connector, I can offer a different method which applies to some late model Nissans...
ACCELERATOR PEDAL METHOD (read carefully):
1 Switch the ignition ON (but DO NOT start the engine). 2 Wait 3 seconds. 3 Within the next 5 seconds, "fully depress - then fully release the accelerator pedal" 5 times (i.e. once per second). 4 Wait 7 seconds. 5 Fully depress the accelerator pedal...and hold it down for approximately 10 seconds. 6 The "ENGINE CHECK" Light should begin flashing. Fully release the accelerator pedal. 7 Read codes as described in the Code Format Description below. Code Format Description - the fault code will be in one of the following Code Formats below: The code is made up of four groups of flashes each representing a digit. A long flash indicates the 'thousands' digit. 'Hundreds' 'Tens' and 'Ones' are groups of short flashes respectively. A long pause separates each trouble code. A shorter pause separates each group of flashes Please note: A '0' digit is indicated by 10 flashes with this system.
Or... Each code is made up of two series of flashes. The long flashes indicate the 'hundreds' digit, however can be a value up to 13 (eg 13 flashes = Thirteen Hundred). The short flashes indicate the 'ones' digit, however can a value up to 15. A long pause separates each code sequence. Once you obtain the codes (or have someone do it for you) from your ENGINE CHECK LIGHT, post the codes here are someone can assist you further. PS: Your first priority is to get the vehicle mobile again. We can then deal with the ABS issue separately. Cheers,
Jul 31, 2009 | 1997 Nissan Maxima
WALL PAPER SITE
www.cellcables.com/motorola-L6-usb-data-cable-drivers-software-free-ringtones-wallpapers-games.php www.cellphone-wallpapers.net/ www.mobileheart.com/cell-phone-wallpapers/210-Motorola-L6-Wallpapers.aspx - Cached - Similar
Jun 15, 2009 | Motorola Mobility L6 Cellular Phone
Wii is soft brick
make sure the cables are completely connected to the TV. consider tech support. they will take it in and fix what is wrong with it.
May 22, 2009 | Nintendo Wii Console
I have motorola l6 phone i want to restore it but its unlock code
Manually reset for L6 Phone
hold * 65512890 for reset
hold * 5806 sw version
hold * 487989 NS lock menu
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
hold * 787090 Lock net level
hold * 787292 Lock net level
here my little trick!
default code is 1234
press menu until the line show 6 digits and enter 000000
done!
Apr 07, 2009 | Motorola Mobility L6 Cellular Phone
FLASHING ERROR 6 L
L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
MOTOROLA L6 UNLOCKING
sir visit this website for unlocking your phone..
http://www.mobile2mobile.net/unlock/RemoteunlockingMotorola.htm
hope i have helped you.. thank you sir..
May 03, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
