Question about ASUS P5N-E SLI Motherboard
P5N-SLI I have this motherboard and i want to buy me the processor , ram and video card. Can i put a 5200 on this card? and corsair TWIN2X2048-6400 5-5-5-15? I also want o buy a 9600GT video card. Thx for help.
    President:
  • 2,351 Answers
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Posted on Oct 15, 2008
Asus P5n32 Sli Premium
There is a couple of things you can do to troubleshoot this.
If there is an on-board VGA (video) port on the back, try that.
Clear the CMOS. On that spec board there should be a coloured plastic jumper next to or near the motherboard battery like this >>>>>
If there is no jumper then remove the power cord from the back and take the motherboard battery out for half an hour then replace and see if you get a post screen.
If it still suffers from the same symptoms then there could be micro fissures between solder points on the motherboard as Intel's tend to run fairly hot.
This means you have to re-float the motherboard and is a last resort repair.
If you need anymore help or advice please post back.
Good luck.
Aug 12, 2009 | ASUS AI Lifestyle P5N32-E SLI...
I have a p5n sli motherboard which refuses to boot
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
Jul 31, 2009 | ASUS P5N-E SLI BULK PACK of 10, Quad,775...
My motherboard is Manli geforce 6100 value and i am instaled Vga card Zotac Nvidia 9500 GT with processor AMD Athlon 5200 x2, ram corsair 2Gb dual chanel, PSU extreme 450. my problem: My PC performance is...
I would back off the 9500 GT and get the onboard video working first.
I would also suggest that you don't have a good enough PSU for that 9500 card, Corsair memory, and the and the AMD 64 x2 5200.
That could account for the slowing down and occasional blank out. The Extreme 450 is much better suited for a milder, stock system.
For that system I would suggest a GOOD PSU at least 650 and preferably 700 to 750.
May 11, 2009 | Computers & Internet
Which One To Choose?
What are you going to use the computer for? Gaming? Or Office use?
The processor is on the high-end. It's actually overkill for normal word processing / internet surfing. It's pretty good if the computer is for gaming.
Your motherboard is okay, but not great. Perfect for office use, but I wouldn't recommend it for gaming. It will not be very upgradable. It lacks RAID, and SLI/Crossfire support, and it only has two slots for ram, not four, making upgrading your RAM expensive.
My suggestion for a motherboard is the Asus P5N-D:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=627&l4=0&model=2033&modelmenu=1
That one has RAID, SLI, two PCI Express ports, four ram slots, and also has a 5.1 sound card built in.
If you do decide to upgrade your video card, I suggest an NVidia GeForce 9800 GTX. They're about $200 and quite good for gaming.
Don't forget the other things your computer needs:
450 watt PSU or better
cpu fan, chassis fan
thermal grease / silicone paste
Dec 24, 2008 | Office Equipment & Supplies
P5ne-sli
Try with only one RAM & isolate the problem
try with different slots
Aug 06, 2008 | ASUS P5N-E SLI Motherboard
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
ASUS P5N-E SLI Motherboard Logo
193 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
